People running ford 8.8s inside please
Old 04-10-2005, 09:29 PM
Valkyn's Avatar
Default People running ford 8.8s inside please
Been pricing some 12 bolts lately and converting a ford 8.8 seems to become more appealing by the day.
So for you guys that are running these in your fbody, what do you think? Would you recommend it or should people stick with a 12bolt/9''?
It seems easy in theory. Get an 8.8 rear, cut the axle tubes about 6'' from the pumpkin, then weld on the axles tubes from your 10bolt cut to the correct length, retaining your spring perches and LCA brackets. Once you have a tq arm mount fabbed you would be good to go, for alot less than $2000 if you were a thrifty shopper.
It seems like the tq arm mounts ive seen people running look like they could be iffy, any feedback on these? Not sure how much pressure these things have on them in a 10 second car.
All input is welcome, but please dont drag extreme chassis into this.
Really wanna hear what people who actually run them have to say about them.
Old 04-11-2005, 10:44 PM
SUX2BU's Avatar
here is how mine broke and what i did to fix it. its a bit over kill but i don't want this bitch breaking again.
https://ls1tech.com/forums/gears-axles/181434-boom-bitch-8-8-broke-pics-inside-kinda-long-story.html
Old 04-12-2005, 07:44 AM
Valkyn's Avatar
https://ls1tech.com/forums/showthread.php?t=181434
What kind of times and 60's were you running when the TQ Arm mount broke, was it an auto or manual?
No trouble with it since you beefed it up? Looks good in those pics.
Old 04-12-2005, 12:24 PM
SUX2BU's Avatar
i thik i was cutting mid to low 1.6's It was an M6. haven't had any problems since. i took it out a month ago and noticed some of the welds are cracked. (welding steel to cast is a NO NO) but i'm not going to f with it antil it breaks again. And besides i went auto now so the shock on the rear won't be as much.
Old 04-12-2005, 04:49 PM
Valkyn's Avatar
So the center section is cast?
Did you go through the proper pre-heating and cool down procedure?
Old 04-12-2005, 08:06 PM
Z95m6's Avatar
build a budget 9 inch much stronger, cheaper and easier.
Old 04-12-2005, 08:26 PM
Valkyn's Avatar
Budget 9'', lets see:
Housing, Axles, Bearings - $985
Differential - ~$400
Ring and pinion - $150
Center - $300
Total - $1835
Feel free to correct me if you can get things cheaper, but for that kind of cash i would rather just spend a little more and get a Strange 12 bolt, setup exactly how i want it, and retain my ABS.
Old 04-12-2005, 10:38 PM
Z95m6's Avatar
Center - $300
Total - $1835
Well the differential ring and pinion costs will be the same on an 8.8 as well as all the work to modify an 8.8 is gonna cost a pretty penny. I personally plan to buy a moser housing, axles, and TA bracket for about $950 then use a spare 9 inch center section i have laying around, but you can go get 31 spline units out of trucks with 3.50+ gears and posi for about $150 off ebay. You can even buy rebuilt center sections off ebay for about 500. Either way thats about 12-1500 for a stout rear end. Also you can build your own 3 channel abs for about $100 more. The stock 9 inch center case is strong enough that most will never damage it. I have a friend that ran for several years on a stock case running a BBC in a 69 camaro running 8's at 160 mph before he broke it. The only reason he broke it was because he was showing off and ran double the amount of laughing gas off the line.
Old 04-12-2005, 10:40 PM
SUX2BU's Avatar
If i could do it all over again i would get a strange w a spool and 30 spline axles.
