ABS Deleted - Possible to remove ABS exciter ring from carrier?
I came across a used 10 bolt, while rebuilding it, I was curious if there was anyway to remove the ABS ring, since I don't have ABS.
Originally Posted by 2001CamaroGuy
I think you can just pull it off but the question would be WHY? Just run with the wires unhooked (thats how I did it).
When you get around to ordering a 12 bolt you can order it without any ABS stuff.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I understand that but for the work (if he wasn't doing a gear swap) the amount of mass isn't going to make that much different.... ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I know it's not much but hey it's a reason right
I bet there are some harcore guys out there that are like hell yea it's worth it.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Bawls I wish I could answer your question but I don't know if it's inbetween the gear and the carrier I wouldn't remove it. If it is attached to the outside of the carrier I don't see why you couldn't remove it. But why do you need to take it off in the first place?
![Icon Razz](https://ls1tech.com/forums/images/smilies2/icon_razz.gif)
