GM LS Diff fluid w/ Royal Purple??
Is this ok? I am going to change my gear oil, seeing as it has not been changed since I have owned the car. The RP says it has friction modifer/LS additive in it.
The guy @ NAPA told me that having too much LS additive would give me chattering problems. I have already bought the RP, need to know if I can add the additive w/o a problem.
Originally Posted by gillbot
I used mobil1 with a bottle of additive and now i'm one wheel peelin. I think i might try regular oil with the additive next year to see if it helps any.
Originally Posted by Screamin_Z
that's ur LSD wearing out, the clutches...not the fluid.
both royal purple, and redline gear oils already have that LIMITED SLIP aditive in it... thats why are more expensive, and better oils... just put them in like that.. without the LS stuff...
That's what I fugured. If I'm laying one leggers, I can allways throw the GM LS Dif fluid in then. I do the change this weekend and update on this. as far as my experiences.
BTW, to the other poster. I am installing 75/90 Synthetic. THe factory calls for...
Originally Posted by BayerZ28's 2000 Z28 owner's manual
SAE 75w-90 Synthetic Axle Lubricant (GM PN 12378261) or Equivalent. W/ a complete drain and refill, add 4oz (118ml) of Limited SLip Axle Lubricant Additive (GM PN 1052358 or Equivalent)
I have the RP gear oil in mine, ive had no problems with it, i put it in at about 25,xxx miles, (and also replaced the transmission fluid w/ RP ATF at the same time) then drove to FL and back the next week, and stayed there in FL for 3weeks. still no problems to date, and i now have 38,128miles as of right now.
I usually top both the transmission fluid and the gear oil off every other (motor) oil change, just to be sure its always at the correct level, but thats just how i am, i change the fuel filter every 10-15,000mi also
