spec 3
Old Nov 7, 2002 | 11:58 AM
alws6's Avatar
Default spec 3
i just ordered one but know i am kind of wondering if i made a mistake after reading a bunch of posts. is anyone having good luck? by the way i have an 01 so i have the better hydrolics. i was told that the old design is the one that had all the problems. any feed back would be great. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Nov 7, 2002 | 01:43 PM
LOnSLO's Avatar
Default Re: spec 3
My Stage 3 carbon is 10 times better than the stock clutch. I have an '02, and just did the drill mod when I installed mine. Great investment!
Old Nov 7, 2002 | 06:30 PM
alws6's Avatar
Default Re: spec 3
i am having the dealer install mine. what needs to be shimmned ( if anything) so i can let him know.
Old Nov 7, 2002 | 06:31 PM
991LE's Avatar
Default Re: spec 3
I have about 25k on my stage 3 kevlar. It is very crisp and is holding great. I haven't run anything but street tires at the track though.
Old Nov 7, 2002 | 07:02 PM
LOnSLO's Avatar
Default Re: spec 3
The kit comes with a green shim. It installs under the slave cylinder. Make sure you have one of these with your clutch. If you don't, call SPEC.
Old Nov 7, 2002 | 07:25 PM
alws6's Avatar
Default Re: spec 3
i am having it shipped straight to the dealer. does it come with detailed instructions or should i call him to tell him about this?
Old Nov 7, 2002 | 11:02 PM
Blackbird's Avatar
Default Re: spec 3
is the adjustable master cylinder necessary with this clutch?
Old Nov 8, 2002 | 12:04 AM
smokinHawk's Avatar
Default Re: spec 3
i have a 99, so thats why i could be having problems with mine, dont know, i have to strat buy parts to find out whats wrong, might weight till spring as im done racing it and it drives fine when i dont run it hard.
Old Nov 8, 2002 | 12:31 AM
Nasty N8's Avatar
Default Re: spec 3
Thats the only clutch we use on all the cars we build. Works great!
Old Nov 8, 2002 | 12:38 AM
thechef's Avatar
Moderator
Default Re: spec 3
i have no problem with mine <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
