Do 99 Camaro Z28's Have A Zexal Locker?????
1 Post
i was told that the 99 camaro Z28 come with a zexal rear locker! is that true, becasue i hav a 99 camaro Z28 M6 and i remember changin my gear oil and i dident see no clutches or anything in the differnsial!
they had a zexel torsen? Yes, torsen consists of worm gears. a locker isnt the same as a torsen. and a Torsen is one of the best LSDs out there. I believe it is very similar, if not identical to how a trutrac works.
correct me if Im wrong.
1 Post
hay thanks alot for the responses guys, and if im not mistaken if i had the auborn i think i would have a bunch of yellow springs and stuff i dont remember seeing those, but thanks anyways guys
It's really not a limited slip. It's either engaged or not and there are not clutches; it's all mechanical. But I don't know that it's technically a "locker".
If you ever have one tire break loose and spin and not the other, such as when turning a corner or in water, it's a torsen (or an auburn with totally shot clutches). If both always spin no matter the circumstances, it's an auburn.
^^^^^yeah my auburn never unlocks you would think it was an old detroit locker or somthing......
to the op place a jack under the rear were both tires are off the ground put the car in gear....if you can spin either wheel you have a torsen....if you cant its an auburn....
1 Post
ohh well yea i hav a torsen then when i spin one wheel the other wheel doesent move or do anything!! but its the torson is there any way this differnsial will break for any reason, for example running drag radials at the track or power brake or doin donuts!!!
Originally Posted by ae13291
is it true that 98's hav an auborn differnsial?
