1LE driveshaft vs. LS1 aluminum shaft
I have a 1LE aluminum that I put on my '94. Since getting into the LS1 world, I have learned what many here already know: that the LS1 cars came with aluminum ones from the factory (with the exception of A4 2.73 gear cars, they still have steel).
Now, here's the question: I looked at the DS on my '99 and yes, it's a nice looking aluminum piece, but it looks smaller in diameter than the 1LE on my '94. I didn't have a tape measure in hand when I was under there, so were my eyeballs correct? I mean, is the stock LS1 piece NOT a 1LE? It looks smaller and is presumeably not as strong (?). I'm also thinking maybe the yoke and u-joints are also not as high-grade as those on the 1LE.
I'm too lazy (and busy at work) to jack up the car again just to measure the DS, so someone help me out here. I would just wait until I have another bit of maintenance to do, but I need the information ASAP.
Thanks!
Thanks!
Re: 1LE driveshaft vs. LS1 aluminum shaft
The LS1 is a 3 inch driveshaft. I'm not sure what the 1le shaft size is....but lingenfelters website says it is a 2 3/4 inch driveshaft.
http://www.lingenfelter.com/lingenfe...mp;pf%5Fid=217
based on this info...I suspect that it is slightly smaller...
Kevin
Kevin
Trackbird,
Thanks That's a great link to answer my question.
So, the LS1 aluminum shaft is even BIGGER than the 1LE on my '94 (3" vs. 2.75"). My eyes lied to me.
Question now is, is the LS1 "stock" aluminum shaft STRONGER than a 1LE piece? How about the U-joints/yoke?
Bottom line is this: I'm about to trade one of those shafts away, and need to know which one to keep and which one to give up in trade. Please give me some input. Thanks!
