Moser 12 = Blowed up = Bummer = Pics
#41
I'd like to keep a GM rear in my GM car (at least a GM design). But I've seen just enough broken axles at the C-clip to not trust 'em too much. It happens.
I really like the ability to drop out the entire center section to change out the gearset if I wish. As you know, that means F*rd 9". The down side of the 9" is the parasitic losses. They're just not too efficient, plus they weigh more.
And on and on it goes. Decisions, decisions.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#44
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Curious why you don't sell the C-clip eliminator equipped axles. Like I said, I've heard mixed reviews on 'em. Maybe so have you?
And on and on it goes. Decisions, decisions.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#45
#47
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
I don't know of anyone who would want c clips in a rear when you get get one without c clips. C Clips fail, and when they do the axle can come out unannounced. In fact, many tracks do not allow the use of axles with c clips in the faster classes. Bob
#48
Question about the C-clips... explain how the axle can come out of the rear end with the brakes still on? Caliper is attached to the backing plate which is bolted to the tube itself?
#49
why do you care...Im not a ford guy but hell, Id rather be use their designed refined by moser instead of replacing GM designed parts every 6 months. Plus, I havnt had the car on a dyno but the "seat of the pants" feeling is the same as it was with the 10 bolt. Still will bounce off the rev limiter with a 2nd gear punch
#50
#51
#55
how bout a hybrid? strange has a dropout 12 bolt 3rd member for a 9"....meaning, it uses a gm 12 bolt carrier/ring & pinion, but setup in a custom strange 3rd member housing, allowing it to bolt into a 9" case
