Midwest Chassis & Performance fab rearends... new pics
#1282
Hey Eric,
What do you recommend for limited slip additive? Break in technique? Grease weight for break in and for post-break in? Synthetic? Any other good info/recommendations?
Thanks,
Addison
Thanks,
Addison
#1283
Hey guys, Im gonna send in my backing plates and rings to Eric. I got the plates and mounts off the 10 bolt and the rubber boot for the ebrake is basically gone. Do these come with a new set of backing plates? Or can I find a rebuild kit or something at Napa? I tried to get the screws out of the cylinder to seperate it from backing plate but there rusted on. Whats the trick to getting these off? I tapped a Philips on each screw and no luck. I threw some PB blaster on em so will see if they loosen up a bit. Im gonna miss the ol 10 bolt, NOT. Got it all tore down, pig out, driveshaft off and plates off within 1.5 hr
#1286
I was in a hurry to get them off and didnt pay attention with the gunk around the head. I had to run my daughter to gymnastics and looked at it better when I got home. There philips headed screw with hex head also. Came right off, now I gotta find a rebuild kit or something with the boot. Im gonna clean up the caliper mounts, backing plates and throw a coat of flat black on them before I send out to Midwest.
#1287
#1288
I just got my rear last week. I am happy with it so far. It is only installed and it wont get any drive time til this spring . My only complaint is the usual and that i was told 3 weeks and it was almost 3 months. Here is a pic of it installed.
#1289
Why wouldn't you just use his torque arm that is custom made for the rear end and sell off your umi?? what i did, and made the deal even sweeter.
I would think the rear with the mount might cost a little more as its something he has to do 1 off, rather then a torque arm he probably has a jig for a knock out real quick.
There has to be some reasons, he includes his torque arm with the rear, and not a bracket that we could bolt to it, and use out torque arm we already had.
Chris
Chris
I'm interested in the cost difference regardless whether its more or less.
#1290
It would be foolish for anyone including Eric to guarentee that road noise or any other noise will not occur when it comes installing to aftermarket NON OEM engineered performance parts. Just a fact Jack.
I have no more noise with the Midwest TA than I had with my Spohn TA. In fact what I notice more so than noise is the feeling of the bumps in the road or going over a bridge etc as a result of the chassis mounted TA.
Now if one has whining gears, the tubular TA is going to amplify the noise more than the stock TA. Again just the way it is. It should also be known that Eric uses a rubber grommet in the lower end of the pivot link and a teflon lined heim joint on the top so there is no metal to metal contact. This will also dampen things a good bit and reduce noise as much as possible.
The Midwest TA does an great job of getting the power to the wheels and not robbing torque as a result of the stock arm or adapter flexing. Since the attach points of the TA where it attaches to the housing are at least 12" apart or so, the thing is tough as nails.
My car is a street car and I am not one bit bothered by road noise at all. The slightly bumpier ride does not bother me either. And if my wife aint complaining, there aint a problem.
#1293
I'm sending payment in for a set-up minus center section within the next 2 weeks hopefully. I'm buying all my center pieces off Ebay for about $800 & that includes a Strange "S" case & brand new Detriot TruTrack.
#1298
Of course if the rear is set up and the moon is aligned right, there shouldn't be noise anyway.. lol
#1299
Well everyone, it's been fun reading all this, but it's time to unsubscribe for me, here's my seperate post on my MWC Fab.9.
https://ls1tech.com/forums/gears-axl...l#post10656222
#1300
the chromemoly tubular anti-sway bar that is setup as a bolt-on kit for my fabricated 9 inch rearend is 350.00 as an option for customers. all you have to do is weld the drop link upper mount bracket to the frame rail next to the stock bracket. you could swap from the stock bar to the race style within minutes after the first install. this setup is the same components i use on the 200 mph top sportsman cars.
