Champion camaro ttix 848 rwhp
Just finished re-tuning Dimetri's 2010 Camaro. Motor is completely stock except for a valve spring change and flow master mufflers. Pump gas and meth. 16lbs of boost. 14 degrees of timing. Customer wanted the 800+ dyno,but will run lower boost on the street.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I dont about that. Kenny bell did testing and the factory rods bend everytime at 13psi...I just dont see the stock motor holding 16psi
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Just finished re-tuning Dimetri's 2010 Camaro. Motor is completely stock except for a valve spring change and flow master mufflers. Pump gas and meth. 16lbs of boost. 14 degrees of timing. motorfiend blue hid wanted the 800+ dyno,but will run lower boost on the street.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
