Where's the leak coming from? (PICS)
Just found a puddle of power steering fluid on my driveway. Got under the car to look and found this. At first I thought it was the pump's high pressure hose but it's clean. I'm trying to figure out were is the leak coming from but I'm not very familiar with this part. Does it have any seals or do I need to replace the whole part?
NKAWTG...N
Is anything above the rack leaking down onto the rack? Or are you sure its the rack/fitting right there? Because the reservoir/pump is in front of the drivers side head directly over that spot also.
I'd say take a rag and wipe all that crud away. Maybe a hairline crack in the rack. Regardless you need to clean it up and then turn the wheel. Preferably while your down there have someone turn the wheel. See where it comes out.
I had a PS leak, turned out the fluid was leaking by the fittings. Didn't use enough Teflon tape.
your leak appears to be coming from one of the pressure lines thats a part of the rack itself. good luck finding those o-rings. you may get lucky finding a hardware store with TONS of assorted o-rings.
unfortuntaly if youre looking for what to buy to fix this its the entire rack and pinion.
that seems very unnecessary. there are o-rings on each line.
Well i tried the o-rings.. and what a PITA.. and it still leaks.. dont know why.. its going to the dealer on monday! And i just got this thing 3 months ago.. car was perfect ! Not to mention i have the infamous phantom no start issue. my car only has 50K on it as well.
