Truck guys!!
Truck guys!!
Alright I've seen some of you guys that have built some really cool latemodel LSX trucks. 1st question: does anybody have one that is 4 wheel drive?
I was staring at my fathers 02' z71 side step silverado and I started wondering,...Most take a 4x4 and jack it up, but what if I lowered it and built the 5.3 to the hilt? Could the stock transfer case handle a lot of power? Is this even a possible idea? Would the gears in the front case be good or bad for racing? Now obviously you wouldn't need the Z71 off road package, that is just what gave me the idea, but to me it would be a race truck that is AWD or RWD by the push of a button. Shaft angles affected? All wheel burn outs sound sweet!!!!!
that would be like the silverado SS truck. The trucks look cool and the awd is cool, except the trannys in the SS's arn't worth a damn. My coworker has a maggie supercharged one and is on his 3rd trans.
There are a couple over at www.performancetrucks.net.. You can get pretty much any info you need from there..
3!! I'd be pissed!
Thanks guys I'm headed to that website.
I guess I didn't read your question right and thought you were talking about launching in 4wd and was pointing out the front diffs are weak. The g-80 lockers in the rear aren't real strong either though.
I would just start with a 2wd personally.
99345 is right cause you are talking about 4l60E pushing a heavyass truck.
Have you checked out performancetrucks.net?
there are lots of fast lowered z71, here are a few that run 11's
Trever1t
Kysilverado
Wilde Racing
kbracing96
Thunder550
Dewmashu
check out their setups, it can be done
Trever1t
Kysilverado
Wilde Racing
kbracing96
Thunder550
Dewmashu
i got a local tuner(well known locally with LSx's) and he's looking at buying my '00 Silverado 4.8 5 speed truck and turning it into a race truck He's thinking of adding a 6.0 to it, stroked and juiced But i'm only wanting $6k outta the truck so he wanted something cheap but still in nice shape
Only the ones in 1500HD and up frames with 6.0L and 8.1L engines. All other V8s had the 4L60E behind gas engines or Allison 1000 behind diesels. Automatics only, some had manuals as well.
