General LSX Automobile Discussion Non-technical LSX related topics.
Can you spin your tires w/ a A4 from a stop?
Old 06-05-2009, 10:14 AM
1gt2nv's Avatar
Default Can you spin your tires w/ a A4 from a stop?
I can't spin my tires from a stop. My car is a a 4 with 2.73 gears. That could be why. I have some junk all season tires. Stock size. Mods are in sig. Could you guys spin your tires with 2.73 gears? My car just grabs and goes. I plan on getting 3.73's very soon. I'm sure those will help the car out some! I hope.
Old 06-05-2009, 10:18 AM
BlacKBirD25's Avatar
i dont see why u couldnt.. if ur really wanting to spin ur tires.. power brake it
Old 06-05-2009, 10:23 AM
aothepresident's Avatar
Yea you should be able to.... I have an a4 with 2.73s and it's not a problem. I have bottom-of-the-line sumitomos though
Old 06-05-2009, 10:25 AM
deelong4002's Avatar
i would think you should be able to spin. How many miles are on your car?
Old 06-05-2009, 10:29 AM
1gt2nv's Avatar
52,000 miles. New plugs, wires and front o2's.
Old 06-05-2009, 10:47 AM
Stephen Griner's Avatar
You should be able to break them loose. You just floor it from a standstill on the street and it wont spin? I wish I had that problem..
Old 06-05-2009, 10:50 AM
therobman's Avatar
no u really need a stall or 373's a a4 stock stall 273 auto is a pig from a dig only way is in sand water or powerbrake it a little to get them goin
Old 06-05-2009, 10:51 AM
1gt2nv's Avatar
Ya, I floor it from a stop and it just goes. NO tire spin at all. I don't want to beat on my car, but you'd think it would spin. Car runs great. Pulls good for the gears it has. No missfires or any issues with the car at all.
Old 06-05-2009, 10:52 AM
oddwraith's Avatar
I can spin mine quite easily, I have nexen 275s and 323s though. I would be VERY surprised if you can spin your tires. Let your foot off the brake from a stand still, and floor it! Make sure you put her right down or it won't break loose. TRY not to shock your whole drivetrain either. When I spin off the line I let the car roll several feet just to make sure the drivetrain is under load, THEN I punch it. Don't let it get rolling too fast though or it won't happen. It's just that you don't really want to be "snapping" it into action. Although if you do you will spin even easier, but not worth it to me. That's just my opinion.
CR71's Avatar
Something is definatley wrong if your z28 can't and my v6 can.
Old 06-05-2009, 10:54 AM
oddwraith's Avatar
**** I just noticed you had lts as well! You should be putting down the same as me AT LEAST. Even though I have an ls6 intake, headers trump that. Could there really be that much difference between 273s and 323s? Hmmmm.
Old 06-05-2009, 10:55 AM
oddwraith's Avatar
x2
Old 06-05-2009, 11:01 AM
colby72olds's Avatar
Mine would barely spin when it was stock, but now it spins to third gear.
Old 06-05-2009, 11:09 AM
1gt2nv's Avatar
I think it's the gears I have. The car pulls ok for the gears. No issues at all with the car otherwise. I do need a tune though. It grabs 2nd pretty good. Chirps some times. I never tryed a brake stand. Don't really want to do that to the stock 10 bolt.
Old 06-05-2009, 11:52 AM
oddwraith's Avatar
Your 10 bolt will hate you more for dead hooking than spinning. If done correctly a brake stand only hurts your brakes really? Someone correct me if i'm wrong here. Even then you can get a line lock. It's all about not "shocking" the system or letting the tires overrun with no resistance. Just don't let it redline if you are brake standing, and then just roll out of it, keeping your rpms midrange. edit: could hurt your tires too
Also, a tune might be just what the doctor ordered. Is it not true that a small amount of low end torque is lost through adding headers? So that combined with the fact that the LS engines offer less low end than the former LT1s did, and the fact that you are 273s could be the reason maybe.
Old 06-05-2009, 11:53 AM
oddwraith's Avatar
Lol. yup with that setup you'd be guaranteed a chirp or two
Old 06-05-2009, 11:58 AM
cabolew's Avatar
https://ls1tech.com/forums/1740913-post34.html linked in newbie faq.
lots of good reading material:
https://ls1tech.com/forums/new-ls1-o...questions.html
Old 06-05-2009, 11:59 AM
BlackonBlackTA's Avatar
I have 2.73s and it doesn't take much to light them up... of course I have some crappy ecstas with about 30% tread left.
Old 06-05-2009, 12:04 PM
02ws666's Avatar
turn traction control off..... jk
Old 06-05-2009, 12:19 PM
rocksws6's Avatar
Stock gears, stock stall, not much power. Not gonna be a real tire burner.
Quick Reply: Can you spin your tires w/ a A4 from a stop?
