10 bolt!!!
50/50 ??? It really all depends. If you hook, it will go BOOM. If you spin you will probably be alright.
I did probably 5-6 passes on my 10 bolt with nitto 555's. Launching around 2200 rpms. Although I spun pretty good.
Since I bought my SS I have been running the 555rs with plenty of track passes on my 10 bolt. I do have 3.73s though but that doesnt make it stronger. Dont dump the clutch though, that will prolly break something. I just slip the clutch, as high as 4500 if the track is well prepped. So as long as you launch it right the chances of breaking the 10 bolt are pretty low with 555rs but much higher with a good launch on some slicks or MT ET street DRs. I heard guys getting deep in the 10s though with the 10 bolts too.
No one can tell you your chances. It might pop, it might not... simple as that. There are things you can do to reduce the chances of it, but there is no guarantee. I made around 100 passes on my 10 bolt with ET Streets doing a quick slip at around 6k and didnt have any issue. Then it popped while making a 1-2 shift on the street. You just never know.
