Post your MPG -VS- Mods
Not sure if this has been done yet, but I see a lot of people asking about MPG vs. their mods. so I thought it'd be a cool idea to share. What kind of MPG are you getting with your car as a DD ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
City MPG:
HyWy MPG:
Model:
Body Type - Coup/TTop/Vert:
Weight:
C.I.:
Speed Density or MAF:
FWHP:
RWHP:
N/A or Boost:
Intake Type:
TB Type & Size:
Trans Type:
Shift Point:
Rear Gearing:
Wheels & Tires:
DM
City MPG:
HyWy MPG:
Model:
Weight:
C.I.:
FWHP:
RWHP:
N/A or Boost:
Intake Type:
TB Type & Size:
Trans Type:
Shift Point:
Rear Gearing:
Wheels & Tires:
DM
MPG: 25
C.I.: ?
Speed Density or MAF: MAF
FWHP: 400
RWHP: 340
N/A or Boost: N/A
Intake Type: LS6
TB Type & Size: Stock
Trans Type: M6
Shift Point: 2500rpm
Rear Gearing: 3.42
Wheels & Tires: 17' wheels (stock spec SS sized tires)
C.I.: ?
FWHP: 400
RWHP: 340
N/A or Boost: N/A
Intake Type: LS6
Trans Type: M6
Rear Gearing: 3.42
I'm getting 19mpg city. I haven't done any hwy since cam install my car is a 6spd 3.90 gear ratio I typically shift around 2200 rpms. Its 346 cubic inches with stock LS6 manifold and stock tire size. Its on a rich nitrous tune also.
I am getting about 17-18 city and 20mpg mixed, 25/26 mpg all highway.
mods: stock with SLP lid, SLP dual/dual and CMS tuned. However, mine is a vert, so I have about 250lb extra weight, plus another 50lb of sub woofer.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
City MPG: 14
HyWy MPG: 24
Body Type - Coup/TTop/Vert: Coupe
C.I.: 427
FWHP:
RWHP: 558.3 (motor)
N/A or Boost:
Intake Type: 102
TB Type & Size: 102
Trans Type: 6M
Shift Point:
Rear Gearing: stock
Wheels & Tires: stock
HyWy MPG: 24
C.I.: 427
FWHP:
RWHP: 558.3 (motor)
N/A or Boost:
Intake Type: 102
TB Type & Size: 102
Trans Type: 6M
Shift Point:
Rear Gearing: stock
I think the format is a little hard to follow. For exapmle, shift points are going to be way different for people with automatics. My trans shifts at different speeds all the time depending on what gear I'm in and the load I'm putting on it. FWHP and RWHP seem a little redundant, if you know one you can figure the other and most people only know RWHP for certain.
Weight would be another big factor to consider. A4000lbs Camaro is going to get worse gas milage than a 3100 Camaro tin can with the same drivetrain.
City MPG: 8
HyWy MPG: 13
Body Type - Coup/TTop/Vert: T-Top
C.I.: 408 Stroker
Speed Density or MAF: Speed Density
FWHP:
RWHP: Not Dynod yet, enough to roast the tires at 60 in 3rd gear
N/A or Boost: Boost
Intake Type: Walbro Dual Intank Setup
TB Type & Size: 90mm Holley
Trans Type: M6
Shift Point: 7800
Rear Gearing: 3.89
Wheels & Tires: 15x10 Nitto 555R 325/50/15
HyWy MPG: 13
C.I.: 408 Stroker
FWHP:
N/A or Boost: Boost
Trans Type: M6
Shift Point: 7800
Rear Gearing: 3.89
City MPG:20
HyWy MPG:30
C.I.: 346
FWHP: 0
RWHP: ?
N/A or Boost: N/A
Intake Type: Stock
Trans Type:6 speed man w/zoom clutch, stock flywheel
Shift Point: City 1-2 at 3, then 2-4 at 3k. Open road, 1@10mph,2nd@20mph,
3rd@30mph,4th@40mph,5th@50mph and 6th@60mph. Fun time=rev limiter
Rear Gearing: 3.42
Wheels & Tires: Stock
HyWy MPG:30
C.I.: 346
FWHP: 0
RWHP: ?
N/A or Boost: N/A
Intake Type: Stock
Rear Gearing: 3.42
City MPG: 15
HyWy MPG: 26
Body Type - T-top, T/A
C.I.: LS6, 346
FWHP: 530-ish?
RWHP: 446 (mustang)
N/A or Boost: N/A
Intake Type: FAST 90
TB Type & Size: TSP 90mm
Trans Type: M6, Twin Disc clutch
Shift Point: 2000-2500
Rear Gearing: 3.42
Wheels & Tires: stock 16s, 255/50/16
i have seen as high as 26.64 mpg highway, but only when i was able to cruise at about 80. when i had to maintain 65-70, it dropped to about 23.5. i think lower gears would help MPG at 65-70, but probably not at 80. my motor also only has about 4,500 miles on it at this point. mods in sig.
HyWy MPG: 26
C.I.: LS6, 346
FWHP: 530-ish?
RWHP: 446 (mustang)
N/A or Boost: N/A
Rear Gearing: 3.42
City MPG stock/mod: 22/15
HyWy MPGstock/mod: 29/22
C.I.: 346
FWHP:
RWHP: 430 (motor)
N/A or Boost: nitrous tune
Intake Type: LS6
TB Type & Size: Ported stock
Trans Type: A4 3600 stall
Shift Point: heavy foot light to light
Rear Gearing stock/mod:2.73/3.42
Wheels & Tires: stock run flats
C.I.: 346
FWHP:
RWHP: 430 (motor)
Intake Type: LS6
City MPG 20
Highway MPG 31
Body Type - 01 SS T-top
C.I.: Stock
Speed Density or MAF: Stock descreened MAF
FWHP: Seriously?
RWHP: 323 recently
N/A or Boost: Stock
Intake Type: SLP lid, K&N filter, Stock LS6 Manifold
Trans Type: M6
Shift Point: Depends
Rear Gearing: Stock 3.42
Wheels & Tires: Stock 17" 275/40 Goodyear Eagle F1
Exhaust: Slp Y pipe, Otherwise stock
Highway MPG 31
C.I.: Stock
FWHP: Seriously?
RWHP: 323 recently
N/A or Boost: Stock
Trans Type: M6
City MPG:15
HyWy MPG:25
Body Type - Coup/TTop/Vert: Ttop
C.I.:346
Speed Density or MAF:MAF
FWHP:480ish????
RWHP:424
N/A or Boost: NA H/C Car
Intake Type:LS6
TB Type & Size: Ported Stocker
Trans Type:M6
Shift Point:6700
Rear Gearing:373's
Wheels & Tires: Privat Netz 19s with 285/30/19
HyWy MPG:25
C.I.:346
FWHP:480ish????
RWHP:424
Intake Type:LS6
Trans Type:M6
Shift Point:6700
Rear Gearing:373's
