Opinions wanted on exhaust - 2000 Camaro SS
I just bought a 2000 SS. The car is in immaculate condition. 6 speed, SLP, loaded. Currently the car has no muffler. It just has a single pipe out the back (drivers side). It sounds good, but I definitely want dual tips. Its smogged and everything...but i cantr decide whether to just split it after the cats and add another tip, or to add a muffler. If i go with the muffler, does anyone have a good suggestion? Borla, Flowmaster, SLP loudmouth? or just leave it and add a pipe? All opinions appreciated.
Probably no LTs...at least not for a long while. Im going to paint the car, get it re-tinted, and get the dual exhaust figured out in the next couple months. After that I probably wont do much to it for at least 2 more years. I want to keep it mostly stock for right now. Should i just keep the muffler off? It sounds nice...
LS1Tech Administrator
Received 1,685 Likes
That part strikes me as odd.
In any event, back to your exhaust. If you like the way the car sounds now (with no muffler), but just want dual tips out the back, then SLP Loudmouth 1 would probably be your best choice for similar sound at the most affordable price for a complete catback. It's almost the same as not having a muffler. The other options you've listed will be at least somewhat quieter than what you have now. Another option would be to just run another pipe on the right side, spliced or Y'ed into the over-the-axle section of the I-pipe (this would be similar to how the Loudmouth is designed).
congrats on the car. in no time you will hate your car so much that you would do anything to avoid it so i suggest you start with the muffler first specially if its your daily driver. mufflers are cheap! also, when you buy any part think for the future because you WILL end up adding parts and power eventually good luck.
Good question.
Based on the fact that you like the current sound, the SLP Loudmouth 1 selection noted above is a great recommendation. Would clean the sound up a bit and you get the dual exit. If you end up adding LT headers in the future, this will result in a very raspy sounding setup.
At times I love a screamer, however if I'm on a long trip I'd prefer something quiet enough where I can have a conversation without yelling. The fix for that was to go with a Flowmaster catback (the original owner had already installed) and then I installed an electronic cutout in the intermediate pipe. That system is mated to Hooker LT headers and an off-road y-pipe. I typically leave the cutout 50 - 60% open and I get the benefit of volume and tone without the rasp. From a performance standpoint, the Flowmaster kit leaves something to be desired however I'm only a button away from max flow with the cutout.
I see these kinds of things amuse you too.
But, back to the exhaust. My car orignally came with the loudmouth exhaust, and I loved it as far as sound. It was pretty bad ***. But what wasnt bad *** was trying to talk to someone when you drove down the road. The magnaflow was a good compromise. the part throttle tone can leave some to be desired, but WOT sounds pretty good. Plus, its pretty quiet inside (except for that damn over the axle pipe that just barely rubs when decelerating and turning left)
1 Post
Flowmaster is trash and the SLP loudmouth can be rather loud at certain RPM's even without LT's. The SLP powerflo is my favorite exhaust currently besides Borla.I have had almost every exhaust on the market on the many LS1's I have had. The Powerflo which is similar to the old SLP dual dual but louder. The loudmouth 2 could be a nice choice also
I like the sound of the flow master with a stock set up like his, makes the car sound meaner than it is, WAY to loud when your making some real power though. I run a magnaflow now so my car doesn't sound like a pro street dragster at the stop lights, lol. It SUCKS sitting in front of a cop at a light when your exhaust is that loud, makes your B-hole about 1/4 its normal size.
I'd say go with a Magnaflow catback. I don't regret getting a Magnaflow muffler with my setup one bit. I've gotten a ton of compliments on how good it sounds. Plus, if you go longtubes in the future you'll have an even better tone.
Looking at the OP's sig, it seems he already went with Magnaflow....probably about 3 years ago when this thread was originally posted.
