Maybe LS6 Intake?
Hi, i was debating about another mod, maybe a LS6 intake, maybe FAST LS6 intake manifold or a stock LS6 intake manifold off a zo6 vette? Is it worth the swap out the stock LS1 manifold for the LS6 manifold? If you make the switch does one have to worry about throttle body switch? Thanks for the input.
Really it all depends on your setup. If you have a basic bolt on or light cam go with a LS6, but it you get into heavy mods got fast. There are a ton of threads on this so if you search you will find a more info but thats basically what you will find.
Yea they did sell them, thats why its so important to confirm the part numbers on intakes or know what your looking at. Because there are LS6 intakes with the EGR provision and im pretty sure there are also LS1 intakes without the EGR on the early C5 vettes
