Fog lights
Otherwise if you are referring to running no headlights at night (why?), before you turn the vehicle on, release the parking brake all the way, then pull it up 1 notch-this will not engage the brake but will keep the headlights from coming on (now you can drive with no lights at all if you want), then just switch the headlight switch to the parking light position mentioned above.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
The fog lights in an unmodified car will only come on when the headlights are also on (either by using the switch or the automatic sensor that detects low-light and puts them on.)
I have, however, seen numerous cars that are modified to allow the fogs to run with the headlights off.
Not saying your car doesn't work that way, but if it does, the wiring has been modified.
Well, at first anyway
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
I did do a mod later to allow the fogs to stay on when the high beams were on (and also the low and high beams on together mod) but the fogs would turn on with just the parking lights on before I did any of that. Those two mods still did not change the requirement for at least the parking lights to be on for the fogs to turn on.
They work fine with the headlights on, whether I switch them on in the daytime, or they came on automatically.
That's strange. All the LS1 cars I have been around between 98-02 could use them with parking lights and I have been around quite a few. I think whatever is going on is specific to your car. I haven't personally messed with any of the lighting switches though so I'm not sure how it would be made to work with only the headlights.
