welding on a iron block 6.0 question
I had #1 rod break in my lq4 and when it swung around it hit (looks to me a oil passage) and left a hole about the size of the end your pinky..my questions is can it be welded up or is it a bad ideal and not worth fixing?
like the guys said it's labor intensive.To do it right need to heat the block to a certain temperature. I can't remember all the process but I think high nickel weld material is also involved. I've heard of old timers brazing exaust manafolds. Where your damage is I would go for new or another block. All the work you've done you have to remember.
Generally, when you weld iron, it cracks around the wield.
If you or you know someone who can tig weld good i think it would be fine. not just someone who does it now and then but someone who welds everyday for 15 years on different materials. On a good weld the parent metal around it should break or crack before the welded area will.as KRLOBRO said "Generally, when you weld iron, it cracks around the weld." Go to the third page that is why, if your welder knows what he's doing it should not crack. http://content.lincolnelectric.com/p...ldcracking.pdf
Me personally though would buy a new block from summit or somewhere you can get a new 6.0 for $800.00 ready to go. i just thought id say that
I've seen industrial diesel blocks repaired by welding big patches and sleeving. Required a delicate pre-heating and post-cooling procedure as well as special (read *expensive) weld rod.
These repairs were only done because a replacement block would be nearly impossible to find. Odd-ball generators, marine engines etc.
I don't think it's worth it on an automobile gas blocks that was manufactured in the tens of thousands.
Too bad you're not in Ore. There's a low mile Lq4 in a wreck at the pick-n-pull…paint not even rubbed off the water pump pulley.
