Obs swap
I have a 2003 5.3 out of a Yukon. Harness throttle body and pcm from 99 Silverado.(drive by cable)pcm tuned vats deleted doesn’t take throttle unless tps is unplugged.changed tps still same thing. Any help is appreciated thanks.
be sure and check out lt1swap.com it will be a tremendous help in the ECU/PCM department.
