MPG focused build
First post.
Can anyone recommend a setup to get highest mpg possible the motor will go into a 2700lb BMW e30( stock 121hp) all the labor will be done in house I'm wondering which motor will give me the best mpg 4.8,5.3, or 6.0. stock hp will be a 3x improvement so hp isnt a concern.
First post.
There's a balance between engine displacement and car weight/drag when it comes to getting good MPG. If your engine is too small, you end up pushing the throttle down more to get the power you need and end up using more fuel. I wouldn't use a 4.8 for this reason. An aluminum 5.3 would be the only choice I'd consider. My Formula, when stock, got 30 MPG on the highway with a 5.7 and a T-56. Your trans and gear ratios come into play for this as well. My T-56 has a .50 6th gear and the engine only turned about 1300-1400 RPM at highway speeds, using a 3.42 gear. Build your engine for great part throttle torque and your MPGs should increase. If wanting to stab an engine in bone stock, I'd look for an L33 5.3 liter. The price increase to get ahold of a 5.7 isn't worth it. I'd only use one if I could score it cheap.
The following users liked this post:
Y2K_Frenzy (07-09-2024)
6.2 LS3 with dry sump oiling
The 1st generation Blazer S10s were a great example of how too little displacement can make mileage worse. The 2.8L V6 got terrible gas mileage, and when they went to the 4.3L, it actually improved. I even had a friend with an early version that did his own swap when the 2.8L died, and his mpg improved as well. Same deal with the iron duke 4 cylinder Camaros vs. their 2.8L V6 counterparts.
That being said, I wouldn't flinch @ a 4.8L pushing 2700lbs. It's not going to have to work hard to accelerate that little of weight. But, the aluminum block L33 5.3L idea has some merit in regards to mpg for a few reasons:
Next level would be to get a PCM with the OS capable of enabling lean-cruise.
- Better F/R balance comparing to the original BMW motor
- Less mass to haul around
- 9.9 compression
DualQuadDave (Today)
- 9.9 compression
Thanks for the replies guys. This seems like it be the most cost efficient way to achieve my goal , I'll mate it to ZF 8hp and hopefully i can get 30mpg+ . The guy that made the 40mpg corvette seems to have it figured out with running his ls1 lean. 30 mpg plus should be doable with the L33 8hp trans and the right tune
