My LS1 died :(
My LS1 died :(
Driving along at 40mph, bucked 2x, saw a "check guages light" saw oil at 0psi and cut the key off. I pulled over, cranked right up (after verifying oil level, ect) the thing had no rattles (abnormal rattles) and idled fine and oil pressure was okay. Then after a few minutes of idling okay it just jerked a couple times and died again. I cranked it again, and again all guages were okay. I drove it home. I dont know whats wrong with this thing, the SES light never came on, just teh "check guages" light. I dont know whats wrong with this thing. WHy is it that my **** is always the stuff that has phantom problems Even LS1's suck for me
Check your battery cables VERY well...totally disconnect them, and look for corrosion. It may be a bit of a stretch, but I've seen this happen, and it was a bad cable/connection at the battery.
try messing with your oil pressure sensor. If im not mistaken if your oil pressure sensor if telling the computer that it has no oil pressure it may do all kinds of crazy stuff like try to shut off
LS1Tech Administrator
Received 1,685 Likes
Originally Posted by Ell Ess Won
GL trying to sell a broken car for 17k lol.
BLKWS.6, Cars have problems from time to time. Some of my cars have had odd issues as well. You can't just give up every time something goes wrong. You'll be buying and selling cars constantly.
Intermittent issues are hard to fix. You may have to wait till it breaks completely before you can figure it out. In the mean time, I'd suggest a PCM scan to look for any DTCs.
Battery cables were TIGHT with no corrosion. The low oil pressure was caused by the dead engine I think, and I never got an SES light so there will be no codes. Also the car seems to idle high (1-1100 rpm at times). I have no clue whats wrong with it I feel like **** though considering everyone told me GM had electrical issues before I got it and I have done nothing but chase them since owning the car (wouldnt start, rpms went to 2500 off the gas intermittantly (already used propane torch to check for leaks) now it dies intermittantly. I have no clue what to think. This thing blows.
Second, GM doesn't have any electrical issues that other manufacturers don't, and LS1s in general are not known for any major electrical issues.
Did you ever fix the other problems? If not, my guess is all the current symptoms with your car may be related. It may take some time to find the issue, and you may have to do some trial and error with parts replacement (unless you just want to wait till it breaks fully).
Don't give up so easy. Checking for vacuum leaks alone isn't enough to toss in the towel just yet.
oh another thing that happened to one of my good friends is his alternator was overcharging the battery. It would come in and out and chug and lights flashing. He drove it home like that ( i was riding with him and his battery blew up ). All the overcharging from the alternator was making the computer go crazy. Can test the alternator with a dvom and check the battery for swelling.
There's probably a few V6's that'll trade you straight across if you're looking for reliability and don't want to fuss with the car. The 3800 SII's are tanks when it comes to milage and durability.
I'd go with the oil pressure sending unit as well. When was your last oil change? How about coolant? Is your filter clean as well?
Im scared to drive it now, its unreliable and I dont want to get stranded. I feel like trading it in and going with something like an RSX-S or something reliable until I can afford a viper or something and a DD for when my sports car dies unexpectedly.
I agree with S99TA, when oil pressure falls too low, it shuts power to the fuel pump in order to avoid engine damage, oil pressure switch might be acting funny on your t/a, like everyone said, don't give up so easy..... Wanna trade??? I'll trade you a Vey Reliable 1994 trans am plus cash???? j/k
