Replaced IAC, now more problems
Replaced the IAC, it now happily idles at 1100 rpm all the time, rpms rise to over 2500 when in neutral and coasting, and my Traction Control turned itself off and would not turn back on on the way home. Got home, restarted the car 2 or 3 times and trac control came online as always, car idled at 1100 each time. I am really getting fed up with this **** guys. I thought these cars were supposed to be reliable. Everyone told me GM couldnt wire a a christmastree if they tried, maybe they were right, but why is it MY **** that has to be like this
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by BLKWS.6
Replaced the IAC, it now happily idles at 1100 rpm all the time, rpms rise to over 2500 when in neutral and coasting, and my Traction Control turned itself off and would not turn back on on the way home. Got home, restarted the car 2 or 3 times and trac control came online as always, car idled at 1100 each time. I am really getting fed up with this **** guys. I thought these cars were supposed to be reliable. Everyone told me GM couldnt wire a a christmastree if they tried, maybe they were right, but why is it MY **** that has to be like this ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
car is bone stock, no tune at all.
Car was warm as it could get.
Went around the entire thing with a propane torch, no leaks, and no whistling, and a vac leak kills stuff, not smoothly speeds it up, its getting METERED air.
No, it drove like a dream for the first week or so. I LOVED the thing, now, its worse than my 88 GT which im thinking of trading back with my dad for. Thank God I didnt sell it to someone else!
Here is hot idle:
![](http://i12.tinypic.com/2i0q2c8.jpg)
Also, I went WOT and it took 5-10 seconds to come down to idle, it slowly drifted down, is this normal on LS1's? or should it drop like a rock?
When cranked, it launches up to 1700 rpm and comes down pretty quick.
What do you guys think, is it normal?
LS1Tech Administrator
Received 1,727 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Who told you that?
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
Depending on the size and type/location of a vacuum leak, it can most certainly casue the idle to "hang up" or raise. Beleive me, I've had vacuum leaks do that, even on an LS1 car.
So you replaced the IAC and it's still doing the high idle thing. But is it still stalling as well? If the stalling problem is fixed and all that's left is the high idle issue, maybe the GM techs can figure out the problem if it's constant now.
Here is hot idle:
also, your saying that the idle goes to 2.5 in nuetral thats when your at a dead stop or when coming to a dead stop? My traction control turns its self off sometimes, but i almost always turn it off anyway.
It was, I re-set things. Also, it idles around 1K until I fully stop, then it drops to that ^ Normal?
is the stalling problem fixed?
So far no stalls and the RPMS havent slowly climbed since my ECU reset...
i think its got somthing to do with the incoming air while your moving is causing the RPM's to stay up a couple hundred untill you stop and the air isint being forced in. in my Z it does that if i take it to 100 and let it coast in neutral it will keep the RPM's around 1200 then when i stop it idles down to around 800. i think your "Ram Air" could exaggerate this effect more than my Z28 will.
Moderator
Throttle cracker / follower make the RPM stay up
until you get to very low MPH. This is normal. But
1000+ RPM is maybe a bit excessive.
This seems to me like a vacuum leak as well. You
have stuff at the back of the intake (AIR, brake
booster, even MAP sensor grommet) that can be
hard to get at.
If it's different than it was, it's not entirely a tune
problem. More likely brought on by mods or damage.
hard to get at.
