Help! How can I tow my car?
My car is sitting on a parking lot - I think the clutch hydraulics are gone.
How can I tow it?
Over here (Switzerland) we don't have the same towing trucks as in North America. Usually we tow the cars using an elastic rope. Here cars usually have a hook or something in the front for this kind of jobs.
GM says to use T-Hooks. Can I use them to tow the car orthey are just to pull the car on a trailer?
Thanks!
Stefano
How can I tow it?
Thanks!
Stefano
The car is parked outside and here is raining - what for a nice job!!!
The sway bar looks pretty practical for this job, I just wonder if it's strong enough. Well, the bar itself is strong, but it hangs on few small bolts.
OK guys, let me try and I'll let you know how it worked out.
Towing is just the 1st problem: I then have to remove the tranny, clutch, hydraulics... rebuild the tranny (that was planned but not for now)... WTF!
Greetings fron Switzerland - to US, Iceland and all the other nations present on the forum
It works, maybe tough on the starter and city driving was a pain in the ***.
I've known at least one guy though that had a hydraulic clutch fail, it got stuck with the clutch disengaged somehow.
Then with the engine off put it in first gear, turn the key. Hopefully your starter and battery are good enough to move the car enough to where it'll start in gear and go.
When driving look way ahead and try not to stop so you don't have to start it like this again.
To shift you just need to get the rpm of the engine to match the rpm of the trans, when you take it out of gear it should be easy-no force required. Then you can press very lightly into the next gear and feel the teeth on the synchros, you feel it though the shifter. You can usually adjust throttle/rpm to allow it to engage. You will fell the shifter moving faster or slower, if you've ever been into a manual trans you can picture whats taking place.
All shifting should be done while the car is right between acceleration and deceleration.
The trans should be safe as long as you don't force the shifter out of gear or into gear.
It might help if you have another manual trans vehicle to practice on first.
