01 z06 question
my buddy is going to look at this car in a little bit, he wanted me to ask around "how much boost i can run and how much power i will make with that setup on pump gas?" http://www.autotrader.com/fyc/vdp.js...sort_type=pric
You can run as much boost as you want. The question is how much boost can you run on a factory bottom end with out forged internals. Most of the kits for a factory motor generally run anywhere from 7-9 psi. Depending on other mods such as lts, aftermarket manifold, h/c ect...the horse power can vary. If its a fully stock motor I would expect any where from high 400s to low to mid 500s with a procharger setup or single turbo running 7-9 psi and a good tune. Im no expert, I would also tell you to check out the forced induction section of the forum.
just a little update, bottom end is fordged and my buddy has a c6 and a c6 z06 already, no need for another c6....he went and looked at it and test drove it, he liked it, prob going to buy it, thanks for the "help".
