General LSX Automobile Discussion Non-technical LSX related topics.
which cylinder is #4??
Old 01-25-2008, 03:14 AM
ae13291's Avatar
Default which cylinder is #4??
hi guys i have threw a PO304 code saying cylinder #4 misfire, so i was wondering which cylinder it is?? if i am not mistaken it is the passenger side 2nd one down starting from the front, correct?? thanks guys and btw what caused this code?? i have another thread on it in the maintanance section
Old 01-25-2008, 03:36 AM
adillhoff's Avatar
You are correct.
Old 01-25-2008, 03:40 AM
venomhp's Avatar
roger! thats affirmative!
Old 01-25-2008, 05:39 AM
caddobass's Avatar
Could be plug, plug wire, or coil. Check them first
Old 01-25-2008, 07:03 AM
SSdreamz's Avatar
thats the one... id say plug or wire unless you recently put in a cam and havent gotten it tuned yet. thats a common code for that
Old 01-25-2008, 08:23 AM
kokingSS's Avatar
DING DING DING you are correct
Old 01-25-2008, 06:06 PM
ae13291's Avatar
yea guys thanks! well first of all i pulled the injector wire and that made the car run more harsh when i revved it and i also pulled the spark plug wire and saw some spark from the coil arcing on the stud, so what options are left??? i changed the plugs and wire lik 200 miles ago!!
Old 01-25-2008, 10:59 PM
Rushin's Avatar
Check to see if the plug fouled out. You might have bought a too cold plug. You also might be leaking oil.
Old 01-26-2008, 12:06 AM
ae13291's Avatar
Leaking oil??? the NGK TR55IX plugs i know are hot plugs! thats the reason why we feel a performance differance with these plugs! factory are cold if im not mistaken! but thanks for the help!
Old 01-26-2008, 11:08 PM
Rushin's Avatar
Yes, leaking oil. As in oil on the plug. Which causes a foul plug and misfire. I didn't necessarily know that you bought the TR55s. Sorry for the misjudgment.
Old 01-27-2008, 12:08 PM
ae13291's Avatar
damm well thanks dude i am gonna i guess check if that plug is fauled, if i remember correctly non of my old plugs showed no sign of oil or anything
Old 01-27-2008, 04:31 PM
Moderator
davered00ss's Avatar
Yes, passenger side, 2nd one in.
Old 01-27-2008, 04:34 PM
dshag's Avatar
It could be a bad coil...ive had a similiar problem and it was a coil
