what "LS" is the 5.3 vortec engine?
im looking into buying a 5.3 vortec out of a 99 fullsize pickup.
is it an LS1, LS2, or am i a dumb a$$ and its non?
if im a dumba$$ get harp on me to much haha
Its in the LS family. It has a iron block with aluminum heads. Not a LS1 which is 5.7. Just a smaller version of the LS1. I think its called a LQ something.
they do have aluminum 5.3s wich i believe is called an lm7, and the two iron blocks flex fuel and the regular are l59 and l33. i dont think the flexfuel is any different besides fuel systems which has larger injectors, different fuel rails etc.....
i wanna build a desent turbo engine for street truck, with a decent size turbo.
so can you use ls1 heads and fuel systems and all that?
how much do u have to punch it out to make it a real ls1?
what HP are u wanting to make?
LS1TECH & Trucks Sponsor
It is definitly LS, regardless of the fast that it isn't an LSx designation. Cams, heads, cranks, etc are all interchangeable. It's already the same stroke as an LS1, so you just need the LS1 bore of 3.89x. When honed an LS1 can safely go just a HAIR more than the 5.3 though, don't go past 3.903
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
If you do not already have the block I would go with one of the Lq iron blocks the are 4.000" same stroke and can be punched .030 to build a 370 turbo motor. the crank and covers are still interchangeable
Correct. The 5.3L is an LM7. There are 2 different types of 6.0L in a chevy truck/gm truck. The LQ9 which is in my truck 364ci only in Silverado SS & Vortec Max & Denali or the LQ4 which is in 2500 series with just a little lower compression. BTW, these engines are great for making power. If you're looking for more info on truck builds, check out performancetrucks.net (this sister site). Good luck to ya.
No love at all for the screamer, devilishly short-stroke, 4.8L LR4, huh guys? I'd like to see someone take the "baby" motor, keep the stock stroke, but bore it out, making it even more oversquare... It'd be something like ~3.90 X 3.2x...
I don't know if that would be feasible or not, but I love engines with significantly larger bores than strokes....*dons flame suit*
I bought a foxbody mustang with no other purpose than to do an LS swap. stock stroke 4.8, LS1 bore = 312ci of high revving fun
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
