Sponsored by: CARiD
Car won't start.
Old Nov 23, 2008 | 03:44 PM
SSwoman2000's Avatar
From: Just kind of everywhere at the moment. I actually haven't been back in my home state for a couple of weeks now.
Default Car won't start.
I have a 2000 Camaro SS that is giving me problems with starting. When it goes to start, everything will kick on electrical wise, but the car doesn't even click to turn over the engine. It has kicked off on my husband driving down the highway, and the other night I went to start it to make a trip to the store and all of the electrical components kicked on, but no click or anything for the engine to come alive. I am trying to find a diagnosis for the car because if I can't figure out what is causing the problem, I may have to trade it in on another SS and I really am trying to avoid it. I have no idea if it is the security system or if it is something completely off the wall. If I could get any help, it would be greatly appreciated.
Old Nov 23, 2008 | 03:52 PM
2001NBMZ28's Avatar
If it was VATS you should be getting a security light. Also could be the battery/battery terminals - I've had them die and have some voltage left, but not enough to crank the engine. Don't trade it, might be something easy.
Old Nov 23, 2008 | 03:56 PM
sweetbmxrider's Avatar
it stalled going down the highway? first i would check for power at the starter when cranking. if there is power, its a bad starter. no power, problem elsewhere. check the cable connections as well.
Old Nov 23, 2008 | 03:57 PM
We tried the battery, it wasn't that. We tried to jump it at a friend's house with their expedition and it still just didn't turn over the engine.
Old Nov 23, 2008 | 04:12 PM
2001NBMZ28's Avatar
With no security light I'd still check the battery/terminals first. If you don't have a digital meter to check the voltage I'd pull it out and have it load tested at a parts store, most places will check it for free. If nothing else it'll eliminate the battery as the problem.
Old Nov 23, 2008 | 04:44 PM
if everything lights up, the battery should be ok. take a hammer to the starter or check the voltage there. sounds like a starter.
Old Nov 23, 2008 | 04:52 PM
Haha, I would love to hit it with a hammer. Then again, if I start, I might not stop. Now the more and more we think about it, it would probably be the starter. Thanks.
Old Nov 23, 2008 | 04:58 PM
no problem just hitting the starter with a hammer usually frees it enough to turn over. of coarse you need someone cranking.
Old Nov 23, 2008 | 06:34 PM
ghardester's Avatar
If it won't start with a jump you probably have a bad battery cable to the starter or bad connection there.
Old Nov 23, 2008 | 07:14 PM
beezer1519's Avatar
^^^ not necessarily, my starter was bad and the car couldn't be jumped if you take a hammer to the starter it usually frees it up like someone else stated... if it's a six speed you can also push start it like i did till i fixed the starter... as for shutting off on the freeway that doesn't happen with a bad starter, as far as i'm aware of... it could be a ground somewhere but first check the starter
Old Nov 23, 2008 | 07:20 PM
1BADAIR's Avatar
starter wouldn have nothing to do with the car stalling
Old Nov 23, 2008 | 07:23 PM
ghardester's Avatar
No, but a bad positive battery cable could.
Old Nov 23, 2008 | 07:37 PM
It is a A4, just so everyone knows. I forgot to mention that before. I know, that probably would have been a helpful tid bit before.
