Diappearing Coolant
My car is loosing coolant every time I drive it. I don't see any leaks, when the car sits there are never puddles under it or anything. I'm dumbfounded. Any idea's?
I replaced my ls1 intake with the ls6 about more than a month ago and it was not doing this so i don't think its the coolant lines underneath because i know they were tight.
Thanks in advance
Matt
Mine has a little green dot on it and it has to line up with the hose from the throttle body. Don't ask me why but I had that little bastard on back wards and started to over heat. I tested it and it was fine. Put it on the right way and it has been fine ever since.
Has the car ever over heated badly before?
If it's not the cap and were me I would pressure test the car cooling system and pull the spark plugs. If coolant comes out of the plug hole than you know where to go next and now have an excuse to pull the head.
Get a new cap, drive it for a couple days, THEN report back if it solved the problem.
When your cooling system is pressurized it raises the coolants boiling point.
I'm not saying it absolutely will overheat but its a major possibility.
It's been about 10 years since I was at auto tech school.
