Car left in parking lot wont start
I had to leave my car in a parking lot because it wont turn over.The battery is fine and the radio,lights,etc work. Security light is not activated and I tryed depressing the clutch pedal sensor by hand and still wouldnt start.The starter is not clicking and attempts at push starting failed.What can it be?
Sure it's not the battery? You can have enough voltage for lights, radio etc. and not enough to turn the car over. I'd see what the voltage is across the terminals first.
Your battery can still put out 12 volts but wont have enough amps to push the starter. Also since you stated that it will not pop start, it leads me away from thinking its the starter.
Its still sitting there i've tried what I could, without having it in the garage so I guess ill have to rent a trailer and bring it it home to work on.The guy that helped me also thinks its wiring/electrical related. The starter never gave me even the slighest problem ever since ive owned the vehicle
The starter does not click and push starting only starts the car for about a 2-3 seconds before it dies again..all the fuses are ok and all connections as far as I can tell are tight.I'm out of ideas.
It does sound like a security issue. I just cant understand what could happen to it and how I can test it? The security light doesnt stay on or anything and ive also tried using my spare key. I will pull off the cover on the steering wheel and look for bad wires or just do a vats bypass
My car did the exact same thing today, but it did finally start. Maybe it's a loose starter wire or clutch peddle switch sticking or bad. Have you ever removed starter and wires off car (loose wire).
Ignition switch related maybe (vatts?). Read Here:
https://ls1tech.com/forums/general-m...need-help.html
https://ls1tech.com/forums/general-m...ont-start.html
I tried doing the vats bypass and it didnt work..so I pulled out the resistor that I bought and cranked the car without the vats plugged in and it worked!how can my car run with the vats unplugged?
Your key may be too worn. Try a new key
Its acting up again. It will start with the vats unplugged no resistor and then if i turn it off it wont so I put the resistor back in and it'll start..right now it started about 5 times in a row unplugged and no resistor with security light on
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
LMAO <not at your problem!!!! just how ******* stupid the VATs in these cars are. im dumbfounded with it i hope you figure it out man.
