Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Camaro and Firebird: How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
Power Steering Cooling Success
#422
Just figured I'd update my power steering cooler status... I decided to remove the Derale cooler I put on last year when I deleted the OE cooler. I notice absolutely no difference without it. So, I'll stand by my anecdotal assessment that all one needs is the upper radiator hose from a non-PSC car to alleviate this issue rather than going through the hassle of installing an aftermarket cooler. It's also nice not having those extra hoses running under there ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#423
What cooler are guys recommending? Id like something small, and what are the diameters of the oem hoses that will go into it?
If I decide to run no cooler at all, can I still leave the oem psc I'm place and simply plug the lines off of it?
#425
3/8
I deleted mine, got a 3/8 x 3/8 brass hose barb and connected the two lines together.
I grabbed that at a hardware store for $4 or something.
Also got the rad hose from the 98? Camaro to replace the one with the PSC in it. That was $15 I think.
Hope that helps somewhat
#426
LS1Tech Administrator
Received 1,704 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yes, this is exactly what I did with my '02 car. I just cut some very short pieces of 3/8" hose, and plugged them with bolts and clamps. This held up fine and would last indefinitely. I had planned to eventually replace the entire upper hose with one from a non-PSC car, but I sold the car before doing so.
#427
Did you notice the ps act any different?
#428
Not at all. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Also, my '98 didn't even come with a stock cooler, and the original pump (very low mileage, like yours) is still doing 100% fine (no leaks, no noises, no loss of power assist).
Earlier in this sticky, there is also a record of my testing of fluid temps without any sort of cooler at all, under normal city driving conditions.
#429
I was wondering about your 98 to see if it had a cooler or not.
The car is city driven and will never see the track but I would like to have the stock stuff in there, assuming it wont worsen the situation if it is blocked off.
Another member reported temperature readings from a car with and without a PSC....both were at 210F.
#430
"For most people, the first time they pay any attention to the power-steering pump is when it either boils over or starts making a horrible howling noise, and this is often during the middle of an autocross or open-track day. LS1 powered F-bodies are notorious for burning up pumps. GM recognized this problem and started installing an oil-to-water power-steering cooler on the '98 SS and WS6 F-bodies, and also providing it as an option on all LS1-powered F-bodies. By 2000, the cooler was standard equipment on all LS1 F-bodies."
If you use the car as a DD or drive like a grandma, (I won't name names...) then you shouldn't have anything to worry about.
#431
Check out the GM High Tech Performance article linked in the original post. From that article:
I probably put 200 miles on it the last three years so. But, I did notice something wrong either way. There is definitely fluid leaking somewhere from my rack. The bottom of the k member has oil, and not my undercoating either. I might just plug up the psc but leave it in place.
#432
I went with a cheap autozone trans cooler and I was getting bubbles in my reservoir thinking it was too much of a restriction.
I moved up to a B&M stacked plate design with 1/2" NPT inlet and outlets. Used a simple 1/2" NPT to 3/8" barb brass fitting to adapt to factory lines.
With the cheap cooler I was getting about 156* after each auotcross run on a 80* day. But my pump was still whining and this is when I observed bubbles. Similar to shaking a bottle of water you see small bubbles. It did not boil over though. 63K mi on the clock.
Went from this:
http://www.autozone.com/autozone/acc...er=267252_0_0_
To this:
http://www.summitracing.com/parts/bmm-70265
Went from this:
To this:
#433
I read thru most of this thread and determined I should go with the Derrale 13224 cooler mounted behind the chin spoiler and install the upper rad. hose w/o the cooler part. It looks like it comes with rubber hose but does anyone know if it's enough hose or do I need more. Also, how much power str. fluid will I need to do the job?? Am I missing anything... is there something else I should have or buy to complete this ??
#434
#436
Thanks for the input,, the cooler and the new upper hose just came today. Looking forward to getting this one done, It's probably the one thing that hasn't happened to this car yet.. every other common problem on these birds has happened to this car -.-.-. but i still love it; maybe it's just a bad habit that's hard to break
#437
Maybe this question has already been answered. Sorry, havnt had time to read the whole post.
Question is, are there any cons to having an aftermarket cooler as far as cold weather goes? Just bought a turn one ps pump and wondering if i should keep the oem cooler or go aftermarket?
#439
I've never bothered to install and aftermarket cooler myself, and I don't know if anyone here in the north has had trouble with over-cooling in cold weather.
#440
It's not mine! woo hoo!
