Front Blinker is Corroded. Need Help Fixing Please
Since I bought my car a month ago the blinkers havent worked correctly at all. When I flip the blinker either left or right, the blinker will just stay on (sometimes the left side will blink as it should, both front and rear, but thats just sometimes not all the time.) When I turn the hazards on, all lights flash besides the front right. So, I got under there to replace the bulb and found the housing to be corroded as hell. I managed to get the old bulb out and put a new one in, but no luck with it flashing. I then went ahead and checked the fuses anyway, but they are all ok.
So my question is, am I going to have to replace the housing? Where do I order it and how much does it cost? I wanted to eventually upgrade the front blinkers with switchback LEDs, so this is as good of a time as ever so do I just use stock housings for the blinkers or do I change both sides out and put in something new. I've read I need to install some module with LED blinkers, otherwise it won't blink correctly?
If you can help me out with this situation I would greatly appreciate it!
housings are 50-70 apiece depending on where you order them, but sure just buy the switchback LEDs they fit in the stock housings
Here are some good links:
https://ls1tech.com/forums/general-m...rn-signal.html
https://ls1tech.com/forums/general-m...t-gaskets.html
Our sockets would last forever and never get burned up if GM had put the socket either on the back of the housing or on the top of the housing. Over time moisture gets inside the the housing and it settles in the bottom (gravity), right into the electrical socket....and thats what causes it to burn out over time. Also, the normal bulbs get HOT because they run all the time, the LED's never get hot so the plastic (stock) housings won't crack and deteriorate over time.
Found them, Amazon:
http://www.amazon.com/Pontiac-Trans-...ar=1&carId=002
They are MUCH nicer than factory, I think they're glass not plastic, and white so they match the headlights and fogs when they're all on. Not that ugly orange colored lenses. AND...SEALED so no moisture can get in. I also did the flashers with LED's.
I got new sockets with wires ready to splice in at Pepboys for $15.00 for both.
Video:
http://s300.photobucket.com/albums/n...lashersvid.mp4
So, we can get the high temp sockets, made of a better plastic. The catch is they are not very available and must be bought in bulk. All we need is 300 people lined up to replace both sockets and we can place an order!
There are old Pontiacs with the sockets on the top of the DRL/Blinker housings....I think the Grand Prix or maybe the Grand Am....not sure. They should have just put the socket on top, then all the moisture in the world wouldn't affect them. The moisture settles into the socket........thats why they fry....
Or just spend $50.00 and get the housings I have. Then the LED's and Flashers......no moisture can get in and no heat from the regular bulbs. And a much cooler looking set up.........
I have a supplier that might be able to get the high temp sockets in lower quantities. If people can reply to this thread, I'll look in to it if there is a good response:
https://ls1tech.com/forums/stereo-el...al-socket.html
Found them, Amazon:
Video:
Order:
EC12 flashers $11.00 each (auto parts store)
48 SMT Tower LED's (white-amber AW) 3157 $27.99 http://autolumination.com/3157_3156.htm
10-15 minutes to install it all and you're done.
Another thing to keep in mind is that the stock parts are designed for very harsh use. Going from the top of a frozen mountain to a burning desert all in the same day, etc. Sealing the lenses completely can be a bad thing, unless they have a pressure relief. If you go to the top of a mountain a couple of thousand feet high, drink a bottle of water, put the cap back on, and drive back down, you'll see the effect. A sealed lens can also cause condensation if the air inside can't move in/out.
