air bag light came on
Bring it to a Pep Boys (or something like it) and ask for them to hook up an OBD-II diagnostic tool to your car. It's free. They'll give you some codes that tell you what's wrong it, that you can match up to ones on a list online.
What year is your car? I had the same issue and OBDI cars have a separate SRS circuit that can only be scanned/read with a TechII tool and does not go thru the OBD port. Mine ended up being the SRS module went bad and replaced it with a used one from a part car that had NON-deployed airbags. If you are OBDII I think it goes thru the BCM and needs to be scanned there, but not sure?
Check all the typical points - sensors, clock spring connector, module connections to make sure they are fully seated and plugged in. Once you figure out the problem, the light will go away and no codes are set or have to be cleared with the SRS system.
It's a 99 obd2. My scanner is higher end than the parts store ones but I don't think it will show body codes.
Funny thing though..I got in it this morning and neither light was on. Could it have been a fluke thing?
My car does the exact same thing. One day it will be on, and then it will just randomly shut off. I had in scanned once and it came back to be a Serial 2 communication disruption imp/dic I belive.. I may be incorrect on the acronyms, but the mechanic said he had no idea what it was.
Thanks for the input fellas. I've been in it 4 different times today and it hasn't come back on. I did have my cutout open last night and maybe the extra vibration shook something while it was going through its self test. I will probably just leave it alone unless it does it again.
Save the manuals!
