01 Camaro Water in Trunk??
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
Ater a rain I discovered water in the trunk of my 01 Camaro. The rear hatch gasket looks ok. Looking for ideas on where to look for the leak. A few months ago the rear brake\turn signal bezels were replaced. Would this be a source of water leaking into the trunk?
BT
BT
My car was parked on flat ground.....it rained like 2-3 days pretty hard while I was away. My rear trunk area had 2 inches of water in it.
I looked everywhere, water tested everything with a hose, and its rained even harder than that since and NO water got in.
I would say to wet vac it out....and move on with your life. It will drive you friggin crazy and you'll find nothing.
Its a mystery........
I'm popping a drain hole in my rear trunk area so the water can get out.......and I'm raising my new amp up 6 inches. My other amp got filled with water......
Or do you mean the seal under the hatch that gets compressed when you close the hatch?
