disconnected vacuum tube
LS1Tech Premium Sponsor
Agreed, part of the AIR system, if you currently have or are planning on getting headers this can be deleted and removed.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
I have Texas long tube headers with egr, cat and air pump delete. What can I do with it if its not being used? I noticed it starts to have a vacuum on it after a few mins of running.
Pull the rubber 90 degree fitting off and cap it. Anyone know if this hose or the place it connnected has anything to do with the cruise control system. I deleted my AIR and i lost my cruise.
It shouldnt, if you disconnected the air system under the fusebox on the drivers side, I would check to make sure that you didnt unplug cruise control as well.
__________________
