Sponsored by: CARiD
dex-cool???
Old Jun 1, 2005 | 10:43 PM
j0n's Avatar
j0n
Default dex-cool???
a friend just bought a mint 01 ss...still has the original "dex-cool" coolant in it and i heard somewhere that that **** sucks lol...so first off, does it? and second, we're gunna flush the system anyway so can we use any regular "safe for all cars" green antifreeze? thanks!
Old Jun 1, 2005 | 11:37 PM
Build #1's Avatar
Dex-cool is fine. Mixing it with green is not ok. It will clump. So if you switch, flush it well.
Old Jun 1, 2005 | 11:41 PM
99BLACKBIRD's Avatar
I heard to only put dex-cool in the LS1's. I heard you can't switch to the green stuff. Is that true?
Old Jun 1, 2005 | 11:46 PM
Build #1's Avatar
I dont think that it matters, Dex-cool is just an enviromant safe coolant. I always thought coolant was coolant. I guess I am not a 100% sure.
Old Jun 1, 2005 | 11:57 PM
Not a reliable source, it was some guy at Oreilley's, he told me some **** about our radiators and how the green **** just gums up or some ****. It was late and I wasn't really listening.
Old Jun 2, 2005 | 12:20 AM
8-Pack's Avatar
Long thread with good info about this
Old Jun 2, 2005 | 03:19 AM
jrivera04's Avatar
There is a green antifreeze, Prestone, at Autozone that is pre-diluted and is Dex-Cool compatible. I used it and so far I've had no issues.
A salesperson told me that Autozone is going to stop selling Dex-Cool because its no longer going to be made.
Old Jun 2, 2005 | 02:55 PM
technical's Avatar
I wonder if that is true. I think it was Texaco that originally made Dexcool and now Shell bought Texaco. Shell is still selling the Dexcool though...for now.
Old Jun 2, 2005 | 10:43 PM
Build #1's Avatar
I work at Oreilly's and there are dumbasses working at my store and every other parts store in town. You just need to weed those kind out one by one. I can't believe he said that it about dex-cool.
Old Jun 2, 2005 | 11:55 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Nothing wrong with Dexcool. It's all about the change interval. I would not wait 100K miles to change any coolant, IMO.
This is interesting. So what will GM be using to fill current and future cooling systems with? Or is it just that the brand name "Dexcool" will stop? Others like Prestone sell GM approved dexcool compatible extended life coolant anyway, this is what I use now....
Old Jun 3, 2005 | 08:55 AM
technical's Avatar
Only use the Dexcool. The glycol (green) antifreeze creates pits in the aluminum.
Old Jun 3, 2005 | 09:26 AM
777's Avatar
777
glycol corrodes alum.
Old Jun 3, 2005 | 10:08 AM
Toasty's Avatar
Dexcool has been proven to be superior to the green stuff time and time again. ONLY use dexcool, its not a gimic.
Old Jun 3, 2005 | 10:21 AM
HBHRacing's Avatar
wow. Thank god. This is a welcome change. usualy when I open a thead like this I have to sort through 90% of the posts saying how bad dex-cool is, how it hurts your car, how it gums up, and how you should switch. I am very glad this is not the case.
Let me just add this. Why would GM design a coolant that wouldn't work better for you then coolant thats been around for decades? It's pretty simple. With the new disigns in both motors and radirators which are now using more alum construction, Dex -cool is constructed to work well with that. It's low silicate forumula is needed if you want your cooling system to work correctly. It's really as simple as that.
Old Jun 3, 2005 | 10:32 AM
777's Avatar
777
Actually it's really as simple as this. If Dex-cool was so bad, GM wouldn't have used it.
