Sponsored by: CARiD
Car won't start
Old Dec 17, 2005 | 10:23 AM
buttermantoast's Avatar
Default Car won't start
I have a 97 Transam i was about to leave from work one day got in my car everything worked the lights came on the interior lights the buzzers were working but when i turned the key to start it everything died the starter will not do anything i was thinkin a fuseable link. If anyone else has had this problem or knows what it is i would greatly appreciate it!!!
Old Dec 17, 2005 | 11:05 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
In the past, I have had issues with a battery having enough power to run all the interior lights but not able to crank the motor. Did the lights go dim when you tried to start it? Could you even hear the starter clicking?
Maybe put a charger on the battery for a while, then see if it'll crank.
Old Dec 17, 2005 | 11:09 AM
I tried to get boosted off from a friend of mine we hook up the cables but it didnt help
and the starter doesnt make any noise!
Old Dec 17, 2005 | 11:20 AM
RPM WS6's Avatar
How long did you have the cables connected? Sometimes you have to let your battery charge off the other car for 5-10 mins before it'll have enough juice to crank.
Old Dec 17, 2005 | 11:44 AM
97MysticZ's Avatar
What's a Sticky?
If you charge the battery and you aren't getting anything it sounds like you probably have a bad starter.
Old Dec 17, 2005 | 11:55 AM
thnx fortunately it broke at work and I work at Oreily autoparts so i will take the battery out and do a test and charge then if its good ima test the starter!!
Old Dec 17, 2005 | 12:29 PM
2002_Z28_Six_Speed's Avatar
Better luck in the future.
Old Dec 17, 2005 | 09:49 PM
Reject's Avatar
well what was the culprite?
Old Dec 18, 2005 | 04:47 PM
Yea i worked on it today i checked all the fuses for the ignition turns out none of them are getting power they were all good but i changed them anyway still nothing checked all the ignition wires goin down to the starter and they were all dead none of my ignition is gettin power i am stumped anyone have suggestions they would be greately appreciated!
Old Dec 18, 2005 | 05:20 PM
steveb1's Avatar
Default Negative Cable
Check the Negative battery Cable. If that is loose (check both ends) or bad then you will experience the symptoms described.
Old Dec 18, 2005 | 09:08 PM
no cause if the neg cable was bad or loose i wouldnt not have all my electric stuff like remote door locks and headlights and interior lights
Old Dec 19, 2005 | 08:59 PM
Shooter_Jay's Avatar
my 02 did about the same thing. Ended up being the ignition relay under the hood. I wiggled it around and it started.
Old Dec 19, 2005 | 09:00 PM
or was it the starter relay maybe, well on the ls1 they are right next to each other. Not sure on your 97 though.
Old Dec 20, 2005 | 06:54 AM
steveb1's Avatar
If your headlights are working, then I agree. Keep us posted on the outcome.
Thanks
Old Dec 24, 2005 | 06:21 PM
Yea fixed it today turned out to be a loose wire goin to the ignition switch under the dash!!
