Low oil pressure in a 98'
LS1Tech Administrator
Received 1,486 Likes
AFAIK, the pumps are the same on the '00 as well. I beleive the update came in '01.
PS. I wouldn't go so far as to say that the older pumps are '****', and not that many motors have locked up in those cars due to oil pump failures. Actually, there are plenty of people just on this board alone with '98-'00 cars that have stock shortblocks and stock oil pumps without any issues....
What sort of PSI are you seeing?
Also, what brand & weight of oil are you using?
And is the car an M6 or A4? (reason for asking is a higher idle speed on the M6 cars gives them a slightly higher psi at idle)
Originally Posted by 98camaroLS1M6
Are 98' LS1s known to have low oil pressure? I know my oil pump is weak and was wondering if others had this problem?
Oil pressure is a little under 40 when warm, should be around 50-60 when warm, correct? Is a cammed M6 with idle around 850-900rpm.5w30 Castrol (Non-synthetic) Wish I would have changed this went I did cam swap. How much am I risking the engine with a low oil pressure?
Little under 40psi at warm idle is just fine, nothing to worry about at all.
Sometimes as low as 30 at idle.
My stock '98 pump in my Z28 makes about 30-35psi at warm idle with stock A4 idle of 550rpm in gear. It drops as low as 25-30psi after a beating, then comes back up to 30-35 after the oil cools a bit.
Am I worried? Nope, not at all.
PS. I've been using M1 10W30 for those readings.
Originally Posted by RPM WS6
I put an aftermarket pump in my WS6 when I did the cam, and had the idle raised to 800rpm. My warm idle psi was about 40-42 depending on outside temp, with the aftermarket pump....and after a hard beating, 35-40psi was more the norm.
What aftermarket oil pump did you put in?
