Dumbest, simplest fix you've done to your car?
Old 03-29-2010, 06:58 AM
  #101
ALLDUN5's Avatar
I had bought a 77 Jeep CJ-7, that the owners could not get running after they had replaced the rusted out hood and fenders. I almost felt bad when I realized the reason it wouldnt start was that the starter solenoid was mounted to the newly installed fiberglass fender. A quick ground wire to the solenoid and she ran like a champ. I got one hell of a deal due to an electrical oversight. It turned out to be the most fun vehicle I ever owned. Now on my third Jeep, but it has a lot more creature comforts.
Old 03-31-2010, 11:25 AM
  #102
Brian Coles's Avatar
Removed a plastic grocery bag from air box. Car wouldn't idle. Stumbled at high rpms. Thought I blew it up with the nirrous!! HaHa
Old 03-31-2010, 11:57 AM
  #103
riceburnerZ28's Avatar
When I installing the dreaded optispark I didn't align the splines correctly and not thinking went to start the engine and it was backfiring like crazy out of the intake. So I thought that maybe I didn't adjust the valves right...that didn't work so after a half dozen times of doing that and a couple weeks later I finally discovered my mistake and the engine fired right up.
Old 04-01-2010, 01:55 PM
  #104
ghettosled's Avatar
Originally Posted by David_viny
Not really a fix, but I didn't know there was a flip out cup holder on the center console for like 6 months when I bought my TA. Now I use it all the time.
took me about 6 months to find this as well. didnt notice it until i was stuck in traffic one day and way looking around the cabin area.
Old 04-01-2010, 02:03 PM
  #105
pheer's Avatar
Originally Posted by staringback05
hearing a clunk in the rear and spending all day checking suspension.....and it end up being the damn spare tire bolt
lol, i just went through this!!
Old 04-01-2010, 11:25 PM
  #106
BOA279's Avatar
really dumb....The day after I bought my 98 camaro I was replacing a blown tranny at an auto hobby shop. I was calling it quits for the day and locked the doors before going home. I stood there waiting for the lights on the rear view mirrors to go out but after 5 minutes they were still on. I checked everything I could and finally out of frustration diked the wires. The next day I looked again and found the dim switch all the way up to "on"
Old 04-03-2010, 03:49 PM
  #107
battousai's Avatar
I had a CEL today, so I checked it out... I had a cylinder 3 misfire. I looked, and plugged the wire back in.
Old 04-03-2010, 03:55 PM
  #108
cutlass_455's Avatar
One time at the track when I was poor and raced a 86 Pontiac Acadian, I broke the throttle cable, so I had to improvise something, so I took the cable that controled the heater damper and attached it to the carb. Made it to the second round that day and had a make shift cruise control until I got it fixed.
Old 04-12-2010, 06:42 PM
  #109
silverbandit0996's Avatar
after i installed my 9" i kept hearing a scraping/rubbing noise when i turned and when i hit bumps it sounded like it was bottoming out. i tried everything, but couldn't find anything. then while i was getting gas a week later i saw two cast iron frying pans, that had been sliding around and hitting each other, sitting in my rear floor board from when i was moving out of my girlfriends house.
Old 04-12-2010, 06:58 PM
  #110
jts98z28's Avatar
hit a deer and destroyed my headlight, only had the plastic lens and the bulb...tin foil and rtv sealant kept water out and made it reflective
Old 04-12-2010, 07:06 PM
  #111
Joshiedoom's Avatar
Went WOT one day, instant backfire at letoff, flashing ses, said cylinder number 1 missfire. Plugwire unbent itself and burned itself in two. replaced with used stocker/heat sleeve.
Old 04-15-2010, 12:13 AM
  #112
omoralesZ28's Avatar
Default idle air control valve
i had an error code on my camaro turns out to be my idle air control valve the car was idling higher than normal so i find and buy the valve 100.00 dollars. so i installed it nothing changed! so i start looking around the throttle body and i find a small hole in the vacuum hose under the throttle body so i removed it and took it to my local auto parts store ask for the same one they dont have it but they found a rubber hose same size openings and let me have it for FREE... moral of the story do a thorough inspect before you go and buy a 100 dollar part thats not needed.
Old 04-16-2010, 04:01 PM
  #113
JohnD's Avatar
I chased a cold idle shake for nearly three years before I finally realized that it was an aftermarket harmonic balancer than had rubber in it that was too stiff when cold.
Old 04-17-2010, 10:36 AM
  #114
BlackBird87's Avatar
Changed out pads on my daily but couldnt figure out why the pedal was so slow to return and why the pads were rubbing on acceleration. Turns out i rotated one of the calipers once too much and kinked the hose.........and im ase certified on brakes
Old 04-22-2010, 12:58 PM
  #115
spirow1555's Avatar
my car smelled like something was burning but no fire or smoke. paranoid, i drove like that for two days.
after bitching at the car and checking under the hood hundreds of times, i looked under it and found out a bag was melted on to the exhaust pipe
Old 04-22-2010, 01:32 PM
  #116
01 ss vert's Avatar
Originally Posted by 9silverbird8
Starting the car for the first time after the Procharger install, I noticed all the tubing to the airbox was collapsing on itself. As it turns out, the air filter can't get that much air if its still wrapped in a plastic bag.
Did they when I degreassed my engine on my old vehicle with a cone filter. covered it to clean the engine, but never took the bag off. Deformed the filter in seconds.
Old 04-22-2010, 01:49 PM
  #117
tuffluck's Avatar
hit a curb once and about 2 years later i heard a loud series of clunks every time i turned my wheels. it got so bad after about 6 months i thought something was going to completely break. thought it was the wheel bearing, the spindle, the shocks, the springs, etc but never really had a clue. i had all the parts ready to order when a friend on this board (mitchntx) said "hey why don't you call this shop and have them look before you start tearing **** apart on your car, since you don't really know what the problem is." so i did, and within 10 minutes they said, "your camber bolt was loose. we tightened it up for you." and i haven't had a problem since.
Old 04-22-2010, 01:51 PM
  #118
ska4life07's Avatar
Originally Posted by tuffluck
hit a curb once and about 2 years later i heard a loud series of clunks every time i turned my wheels. it got so bad i thought something was going to completely break. thought it was the wheel bearing, the spindle, the shocks, the springs, etc. i had all the parts ready to order when a friend on this board (mitchntx) said "hey why don't you call this shop and have them look before you start tearing **** apart on your car, since you don't really know what the problem is." so i did, and within 10 minutes they said, "your camber bolt was loose. we tightened it up for you." and i haven't had a problem since.
Oh man! hahahahaha! I just picked up my car from the shop and they said the same thing to me.
Old 04-22-2010, 01:57 PM
  #119
mike171562's Avatar
I drove my car for two weeks with a random misfire, I couldnt figure it out. Finally I got a code. Cylinder3 misfire, sure enough, i pulled plug 3 and there was a tiny hairline crack in it.
Old 04-23-2010, 06:37 PM
  #120
tuffluck's Avatar
i had a story that could have gone in the books for a lot of people.
i changed my alternator and then got in the car while the car was still jacked up and cranked it. for some reason it was idling about 100rpms. wtf??? i thought i forgot to plug something back in or i tore some wire when i installed my alternator. so i thought about it for about 30 seconds and then said, "wait, i'm low on gas, i wonder if while the car was jacked up, all the gas sank to the back of the fuel tank?" so, i lowered the car from being jacked up, cranked it, and it was fine.
i could see that taking a lot of people 4 hours to figure out!!!
Quick Reply: Dumbest, simplest fix you've done to your car?
