Does this sound like a Wheel Bearing/Hub Assembly problem??
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I've had a clunking sound in my front suspension for a while, and crappy tire wear for a few months now. I finally decided to take a look at it here on my lunch break. I found that front pass. side wheel is solid, but I can grab the driver's side back and forth(left and right) like half an inch either way
but I can't move it up and down at all. Does that sound like a wheel bearing/hub issue or a tie rod?
Thanks in advance
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Thanks in advance
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
In thinking about it, I guess I kind of answered my own question. I could see the outer tie rod moving when I was moving the wheel. I guess the wheel itself is supposed to move, and the tie rod in combination with the rest of the steering linkage is what's there to stop it.
Next question would be, how hard is a tie rod end to change?
Originally Posted by alamantia
tire rod is easy to change provided you have a seperator and its not to rusted up. You will have to have the car alligned after you change it though
Thanks for the help
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
as much as i cringe at the thought of going to autozone they do offer loaner tools if you dont feel like buying the fork, but they are pretty cheep and its good to have if you feel you will be doing future front end work, my blazer eats idelr arms for breakfast, every god damn year i tune it up and replace the god dam idler arm, i almost look forward to it now, its like I go to the parts store every year and say i'll take some plugs, cap rotor, air filter PCV valve... and oh yeah, idler arm please i bit the bullet and bought one.
Wow, sure am glad I bought the pickle fork, those things were on there! Steering feels a lot better, more solid and a lot more smooth. I don't see why GM didn't put greasable suspension components on in the first place.
Another thing that sucks was when I was loosening the lug nuts to take off my wheels, one lug on each side twisted off the hub
Wtf kind of garbage material do they make lugs out of that they would just twist off like that?
Does that mean the hub has to be replaced?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
