Car won't start after new starter install. Ignition switch?
Replaced the starter in my 01 T/A on Saturday. Everything was fine until I went to start the car. Nothing happened. I have no guages, no radio, it won't crank, and no power is going to the starter (on the purple wire.) Hot wired the started and it's fine, cranks the motor, but won't start. I have power to headlights, mirror overhead lights, door chime, and brake lights, and hazards. Pretty much everything you don't need the key in the ignition to use. I dropped the column and the actuator is moving when I turn the key, but something tells me the switch is bad. I've tried starting it in park, neutral, and jiggled it while in park. I just want to verify with the experts (you guys) before I go buying parts I don't have money for.
(sucks too, because I had my windows down while doing the starter, and now I can't get the windows up, so I have to strap on a tarp over my car cover.)
Its not the ignition switch.. If it was that would mean everything would still work like headlights, interior lights and all that kinda stuff.. If it was the switch when you would go to crank it, it would do nothing i mean not click nothing but the lights and accesories would still be working..
My guess its a wire running from the battery to the starter.. Somethings not hooked up right
I replaced the starter after one of the interior gears in the starter decided to break and let the starter motor free spin.
Did you check all the fuses?
Did you disconnect the battery before working on the starter?
Did the switch work before the starter replacement?
If the switch went bad while you were replacing the starter that would be unusual.
And, remember you have to pull the steering wheel if you do replace the switch. There is a hold down screw inside.
Be sure to disable the air bag before you start.
All the fuses are good.
We didn't disconnect the battery till after we had the starter unbolted, but we left the started wired up, i wanted to see if it was the starter that was bad or the teeth on my flywheel.
The car started fine before the starter died. And even after the starter died, i had good power.
I had just about the same problem with my wife's 93 Camaro! After two days and a new relay and fuel filter. I took a piece of wire and held it on the ground of the battery and to the bolt where the main ground was installed. My friend then turns the key and she furred right up! I took a self tapping screw and and mead a new ground location! This fixed all the problems electricity that this car had! It might work for you as well. My car sat in my garage for two years before I decided to get it ready for the road again.
My 2004 Lincoln aviator want start after the starter been put in correctly...all I get is 1 click noise when I try to start the car it's been like 4 different people trying to get my truck started but nothing! The last guy took the starter to get it check was told the new starter is good and bad starter isn't...we also put jumping cables on my truck but still nothing! I got the brand new starter and battery about a month ago so both parts are new..I need some advice I'm losing hope don't have money to put in shop..
Good luck.
BTW, it's usually a good idea to start a new thread instead of posting in an existing thread that is several years old.
