Car Not cranking!!!!
i had to replace the wire that sense's the resistor in your key on a 99 ss. he couldnt start his car without the security light coming on
Starter relay
If your security light on the guage panel is coming on,it could be the VATS system.Basically the security system that reads the little pellet on your ignition key that was mentioned.
Let us know how those go...
Subject: Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt) #02-06-04-015A - (03/07/2006)
Models: 2001-2007 GM Passenger Cars and Light-Duty Trucks (Including Saturn)
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
with Side-Mounted Battery Terminals
This bulletin is being revised to update the models and provide a new labor operation number for this repair. Please discard Corporate Bulletin Numbers 02-06-04-015 and 03-06-03-006A (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on an intermittent no crank, no start condition.
Cause
This condition may be due to poor battery cable connections. Cross-threaded/stripped battery cable bolts inside the battery side post terminals may cause poor battery cable connections.
Correction
To avoid replacing the battery , do the following steps:
• Clean the threads in the battery side post terminals using a 3/8" (#16) NC bottom tap.
• Replace the battery cable bolt.
The battery cable bolt is serviced separately from the cable and is available from your Parts Department. Be sure to use the correct bolt.
... maybe this will help (sorry so long)
I think he's saying to switch them to see if it's your ignition relay that is bad.If you switch a potentially bad ignition relay with the good fan relay (if I'm correct),it should start.If it does start,turn the car back off and buy a new relay for the ignition relay slot and return the fan relay accordingly.
I believe thats what was meant by BLULS1Z28's post....Sorry if I'm incorrect.
