anybody elses oil filler neck loose???
1 Post
hey guys im really annoyed at why my oil filler neck is loose!! it makes me mad whenever i look at my engine bay, i can make it straight but it will get a little wiggly sometimes.i have tries to remove it but had no luck!! does anybody have a fix for this or does anybody else have the same problem??
i dont think anybody is going to answer right now..lol
but i actually have the same problem since its just in there it moves around but wont come out.
1 Post
yea kind of a gay problem! i was gonna take off the valve cover hoping to be able to fix it!, but i heard somebody still wasent able to fix it that way either
Mine's stuck, but there's a rubber ring at the base, by the heads, that's half in, half out. I don't think it's supposed to be like that, but whatever works, I guess.
Btw, I bought it like that, so I have no info on the ring.
is it threaded into the valve cover or is it the push in style? i know after awhile of heat cycles the VC's will make the hole expand a little. try teflon tape around the threads if it has them.
1 Post
yea mine seals good too! but i think there is some type of vacum leak! when i first bought the car i would open the oil cap while the car is running idle, and the rpm's would drop down a bit, now when i open the cap, the rpms dont change or anything??? weird i think its leaking or something! should i worry bout this
