Gas in oil and weird gunk under the oil cap?
So recently I got the "Low Oil" light I get every few tanks of fuel or so and went to add a quart of Mobil One. I added the oil and then when I went to put the cap back on I noticed a bunch of weird gunk under the oil cap:
![](http://www.greatermud.com/Images/OilCapWeirdness.jpg)
I also noticed the oil smells very strongly of gasoline. Anyone have any ideas what this gunk might be or why the oil smells like gas? It's been several months since an oil change, but I don't do much driving (~30-40 miles per week). Am I looking at just an oil change or something more serious?
It's an '00 WS6 with 73k miles on the clock.
I have seen this on a number of cars.
My guess is that it is the result of condensation formed when the oil is cool, being boiled off where it rises to the top of the engine. When the steam/water vapor cools, it mixes with the oil and turns to the same kind of sludge that results when you blow a head gasket (the coolant/oil coffee looking mess).
If your oil looks fine, you shouldn't have any problems.
I'm hoping that's my problem since my driving habits definitely fit that description. My commute is like 2.5 miles each way (.75 of that is taxiing in/out of my apartment complex and parking structure at work), and it's pretty much all stop and go.
I know I should be taking better care of her, and I plan to when I actually get into a house and have a damn garage to work out of. Our complex discourages us from working on our cars at all, and even frowns on popping the hood.
I hate California.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
During this time of year I get that. Must say I check my oil once a week though, so it never looks that bad. It really depends if you take a lot of short trips or you don't let the engine get up to running temp.
I've never seen it that bad from just quick-trip driving.
First off, is the car running well and idling smooth? If not then it's time to worry.
I second the notion to run a compression test. If one or two cylindars are losing compression then get out your tools and pull those heads because the gaskets are shot.
Yeah... Test your compression. Then you're gonna want to buy some headgaskets, radiator flush, engine flush, valve cover gaskets, plugs, oil, oil filter, and get to work changing those headgaskets.
The dire issue isn't your plugs or the fact that you're loosing compression; it's the fact that you're filling your crank-case with water, and that takes away the lubrication qualities of your oil.
In short, don't drive it anymore until you have it fixed.
