- Camaro and Firebird Why Won't Interior Lights Turn On Off<br>Guide to diagnose trouble and recommended solutions.
See related guides and technical advice from our community experts:
- Camaro and Firebird: How to Repair and Replace Body Control Module
Step by step instructions for do-it-yourself repairs
Browse all: Electrical Guides
LS1 Body Control Module Problems - The Fix
99 Trans am
First off, the radio, windows, and dome lights work and are not cutting in and out while driving. The bcm is clicking only when the radio is already off and the key is turned to the on position. The radio will stay on like normal when the key is turned off and will stay on until the door is opened like normal. If I turn the key on then off(with door closed so the radio stays on) and then on again it will not click. Also bcm will not click if I remove only the radio fuse and turn the key to the on position. But it will still click if I remove only the courtesy fuse. It also seems to do it more in the cold weather. I do have an aftermarket radio and speakers but no amp, other than the stock one.
I have found these wile searching if it may help anyone else
https://ls1tech.com/forums/general-m...y-10-secs.html
https://ls1tech.com/forums/general-maintenance-repairs/1624840-clicking-passenger-side.html
Thanks in advance
I had a terrific day learning about my 99 FB. I didn't fix the BCM yet, but at least I understand it now, and simply make sure to put on the ac when it heats up and shuts off. It was 80 today so I got to experiment a bit. Got the soldering iron and will attempt to remove the BCM this week. It looked really tight in there when I peeked.
Having fun in my new FB and all this great info on here.
The mirror lights will come on by the switch on the mirror but used to come on when the doors were unlocked with the remote and when the ignition was turned off, now they do not.
Is this a door pin switch issue or BCM issue?
BTW I repaired my BCM about 2 years ago.
I've had 3 LS1 cars over the past few years that had intermitent body control module problems. When your radio and power windows intermitently go on and off, it's a body control module problem. This must be somewhat common and most people probably don't know where the problem lies.
Today I took a shot at trying to fix the module itself as buying a new one is around $200. You can buy a used one but then you have to know the VIN of the car it came out of so you can get the VATS code and make a new ignition key for your car that matches the used BCM.
The BCM is located on the passenger side under the dash just behind the glove box. To my surprise, the entire circuit board is just sitting inside a black plastic box that unsnaps. Unsnap the box and remove the entire circuit board. I was able to isolate the problem to the main power circuit/plug-in. After playing the wiggle-parts game, I found that the relay just behind the plug was the problem. There are 5 solder joints holding the relay onto the board. One solder joint looked like it had a super tiny micro-crack in it. I heated that one solder joint and added some additional solder and whaddayaknow !!!! it fixed it ! Your mileage may vary but I would reheat each of the 5 solder joints.
Here is a picture of the circuit board with the 5 solder joints crudely circled. The bottom joint was my problem.
Just thought you guys would like to see this.
Greg Crowe
http://www.camarofirebird.com
Driving back from lunch today the radio just cut off and pressing on the face plate (which has fixed it every other time that happened, including several times on the way to lunch) did nothing so I try the windows and nothing, then it just randomly starts up again while stuck at a light and goes fine till I get to work and as soon as I shut the engine off the radio and windows stop working (even tho the doors where closed) so I put the key back into the run position and they come back then I pull the key and the radio stays on till I open the door like normal.
do you need to disconnect the battery before removal or can you just unplug the BCM?
I think mines starting to get flakey again. It may very we'll be my drivers door switch though. Every once in a while my radio stays on when I shut the car off and open the driver door, but it shuts off if I go to the other side and open the passenger door. So I'm thinking maybe the door switch.
I would guess that you have corrosion in the bulb socket. They are notorious for collecting water and corroding causing intermittent operation. Sometimes you can clean the surface corrosion on the contacts and then apply dielectric grease to reduce future problems but sometimes you just have to replace the socket.
like today, nice sunny clear 60* day, going to lunch the passenger DRL wasn't working (but turn and parking where) then when coming back from lunch (30 minutes later) as soon as I lower the parking brake both come on. to me this seams more like a module issue then a wiring issue. Are the DRL modules known to suffer from the same solder crack issues as the bcm?
