Sponsored by: CARiD
Old Apr 29, 2016, 04:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Browse all: Electrical Guides
Print Wikipost
LS1 Body Control Module Problems - The Fix
Old May 17, 2010 | 07:18 PM
  #161
nascarnate326's Avatar
Would this issue cause my car to have issues with Security sometimes, then all the sudden not work after I hit a huge pot hole? Got a new key, test key switch, key class 14, I have a vats bypass box, and still cant get the car to start. Going to try and bypass the ignition relay but I may try this first.
Any ideas?
Old May 18, 2010 | 07:09 AM
  #162
WhiteBird00's Avatar
Ungrounded Moderator
This is completely unrelated to VATS or any starting problems. The solder joints mentioned apply only to the Retained Accessory Power (RAP) circuit of the BCM.
VATS is also controlled by the BCM but it is not the sole reason for starting problems - people have had starting problems long before circuits like this were added. If the SECURITY light in the instrument cluster isn't on or flashing, it's a good bet that VATS is not the problem. The starter relay, the starter itself, and the wiring between them are good candidates.
Old Jun 5, 2010 | 10:13 PM
  #163
2000firebirdformula's Avatar
hey man im tryin to pull out my bcm to fix the solder points but the very first black piece wont come out i have both of the snaps off but at the very bottom where it slides on the round nub i have 2 metal flaps on there keeping it from coming off. was yours like this?
Old Jun 5, 2010 | 10:21 PM
  #164
SparkyJJO's Avatar
Talking about the kick panel? Yes there is a metal clasp thing. I didn't realize it at first and just pulled and it came flying off
You can grab the little metal clip with pliers and coax it off.
Old Jun 5, 2010 | 10:22 PM
  #165
haha ya that clasp thing....i can jus pull that off
Old Jun 5, 2010 | 10:37 PM
  #166
SparkyJJO's Avatar
Yep. Its a pain because you usually bend it up a bit taking it off, but it straightens out OK.
Old Jun 6, 2010 | 11:48 AM
  #167
alright got everthing put back in, everything works hopefully it stays that way haha....that bcm is a pita to get out i thot i was going to break it haha but its pretty easy to get back in thx for the help
Old Jun 13, 2010 | 11:16 AM
  #168
pemberton's Avatar
I just wanted to add that I had problems with my interior lights flashing every 10 sec and my radio would not come off when I opened the doors to get out. I reheated all the joints in the and added more solder and it worked! I did not have any problems with my power windows that I noticed.
Old Jul 15, 2010 | 05:01 PM
  #169
01ssreda4's Avatar
Where is the original post??? OP whats the deal?????????
Old Jul 15, 2010 | 08:52 PM
  #170
The OP left the forum in a snit and deleted all his posts. All the information you need about this fix is repeated elsewhere in the thread (including photos).
Old Jul 20, 2010 | 01:51 PM
  #171
ISMELLRICE's Avatar
wow this is about 100% my problem lol
i bought the car and the guy said the windows and stereo worked a couple days before, they didnt work that day, took it home and passenger only worked but no stereo or driver window, now nothing works stereo or either window so im checking this today...
**crossing my fingers and i will update in a few hours**
Old Jul 20, 2010 | 07:47 PM
  #172
ISMELLRICE's Avatar
WORKED! did it...only took me about 20 mins to take it out, solder the 5 spots and slap it back on...
$8 soldering iron kit from walmart and i have radio and windows now lol im happy,
thank you so much guys i appreciate this alot!
Old Jul 22, 2010 | 11:02 PM
  #173
bravo863's Avatar
Smile Thank you all!!!!!
Originally Posted by SparkyJJO
I see that the original poster removed the contents of his post and the picture. Why I have no idea.
Anyway, for those who need it, here is a pic of the bottom of the BCM with the big solder joints in the shape of a T circled.
I have a 1997 ws6 and have had this on going problem for a long time.. No one at the dealerships could find the cause... Thank you all for posting such detailed instructions... My radio and windows are back to normal.. Thank you
Old Jul 29, 2010 | 08:51 PM
  #174
2001somws.6's Avatar
Great thread!!!
Old Aug 1, 2010 | 07:12 AM
  #175
SS4Luck's Avatar
**** i just read this whole thread and saw the problem im having addressed a few times and not one answer.
I have no interior lights, no power locks, it sounds like something is clicking at me every 10 seconds i have a dead as dead can be battery but my power windows work. I dont have a key fob to see if that works.
anyone?! im seriously about to shoot myself over this
Old Aug 10, 2010 | 02:53 PM
  #176
mike171562's Avatar
My Radio and Windows were cutting out randomly , I did this yesterday and it worked! don't know if its related, but when I pressed the remote to lock the doors sometimes it would only honk once , It honks twice now like its supposed to. The BCM is a bitch to get out, I used a flathead screwdriver to press outward on the sides of the clip holding it in and just brute-forced it out. Left the two smaller plugs plugged in and soldered it in the case while still inside the car.
Old Aug 15, 2010 | 08:17 PM
  #177
myk's Avatar
myk
Don't know if this is a coincidence or not, but after I did the solder fix my AM radio reception became horrible. I've checked the connections to the head unit, power antenna, etc. but I don't see anything. Is there any way I could've damaged something while working on the BCM?
Old Aug 15, 2010 | 09:36 PM
  #178
SparkyJJO's Avatar
The AM antenna is internal to the radio.
Old Aug 15, 2010 | 10:45 PM
  #179
88gtman's Avatar
Thank you for posting this. The car I just bought has this problem. I will get to it as soon as I can and report back how it goes. Thank you, thank you, thank you.
Old Aug 16, 2010 | 07:28 AM
  #180
No, the AM antenna is the same as the FM antenna - on the right quarter panel.
