Pacesetter Lt Hitting Driver Side
Old Oct 26, 2008 | 06:24 PM
rossina00's Avatar
Default Pacesetter Lt Hitting Driver Side
K I Know This Is Old But My Lt And Y Are Hitting Under The Driver Side Ive Put On The Mufflex Piece And It Helped For A Little Bit But Then Went Back To Banging Again Any Help Please.
Old Oct 26, 2008 | 06:37 PM
WS6R6's Avatar
CAPITALIZATION necessary?
Try banging down a little on the top side of the y-pipe where it hits the floordoard and it will go away. That is how it is on the SS and have not had any problems whatsoever!
Old Oct 26, 2008 | 06:42 PM
rossina00's Avatar
Cool Will Try I Dont Know What Else To Do But Ill Try That See What Happens.
Old Oct 26, 2008 | 06:52 PM
ChevyRyda99LS1's Avatar
I had the same problem muffler shop fixed it try a local muffler shop they will know how to fix it
Old Oct 26, 2008 | 06:58 PM
bluestrat's Avatar
Poly Motor Mounts is the only real way to fix this. The real problem is caused by the torquing of the motor. Putting exhaust hangers on essentially makes your exhaust system another motor mount. Go straight to the source and replace the mounts.
Old Oct 26, 2008 | 07:10 PM
DaveX's Avatar
Agreed, this is the only cure I found. I tried 3 different Y pipes and spent alot of time adjusting and prying on them but it always came back until I swapped out the mounts.
firehawk#682's Avatar
^ x1...
Old Oct 26, 2008 | 09:06 PM
camaroracer91's Avatar
do all pacesetters do this
Old Oct 26, 2008 | 09:23 PM
jrpimp00's Avatar
I took off the y and used blocks of wood and a floor jack to make an indention in mine. Put all the weight on the jack and it made a perfect fit, no more banging. And my BBK flange was literally wedged against the floor board, couldnt even put a peice of paper between them. Now i got about 2 inches.
