Power loss and backfires afer exhaust install
I recently installed Pacesetter LT's with custom H-Pipe true duals. Now my car has no power at all and constantly backfires after it gets warmed up and it kind of lurches and backfires really bad at WOT. I know there is some loss of low end torque after LT's are installed but I don't think that it is supposed to be this bad. It doesn't have anywhere near the amount of power it had before through the entire RPM range. What could possibly cause this?
I'm agreeing with everyone else. first time i installed my headers my buddy dropped a plug and it cracked the porcelain. it wasn't noticeable until I found which cylinder was misfiring and I had to inspect the plug pretty close to find it and even then almost overlooked it. If all your plugs and wires are good and tight it might be an exhaust leak. I doubt a leak would make that much ruckus but it's possible
I figured it might be the plugs, so I bought some TR55's. Although I won't be able to install them until this weekend. If that doesn't fix it I'll replace the O2 sensors. How much would those run and what kinds should I look at?
Had the same problem, make sure the plug wire clicks twice to make sure they're on good. I thought mine were tight until my friend got in there and proved me wrong. Great ever since!
Pulled the plugs today. Number 6 was cracked and number 7 was shattered. The ceramic had split down the middle and fallen off. Now the car runs smoother than ever and feels like it has more power than it ever did. I also replaced the O2 sensors because they were fried.
