Ls1 runs for 5 seconds shuts off Not VATS
What else could cause this to happen besides the VATS. I had the VATS taken out of my PCM. I have all sensors plugged in that I know. Not sure what else it could be, please help.
I cant get it to run for more then 5 seconds ever. Sounds like if the pcm thinks its broken and goes into speed density mode then it will run after that but it never does. You can start it rev it up and it just dies. Sometimes it has a hard time starting other times it fires right up. I don't have an obd II connector yet so I can't read codes or anything. I know they are cheap.
Thinking now it has something to do with the oil pressure sending unit. Its plugged in and I don't think its broken but it may be bad or something. I believe the pump is working but I looked in the valve cover through the hole and it looked pretty dry.
