How to install LS6 Intake Manifold Video
I am working with myspace technicians right now to see if we can get the videos working again. I'm hopeful that they will be up soon. Hi Ceilan,
Your request regarding the two non-working videos has been forwarded to the appropriate department. We appreciate your patience while we work to resolve this matter.
Sincerely,
Steve
The MySpace Support team
Thanks again !!!!
I did this job today. I already had the LS6 type coolant tubes so I didn't have to remove fins. My OPSU (oil pressure sending unit) is not a GM so my PVC hose is against a bronze 45*. I had to swap over the throttle body studs from my LS1 to the new LS6 intake and swap over the MAP sensor. I put in new gaskets but left the foam alone. My bolts are kinds old so I only went to 75 In/Lb
For those of you who get a LS6 intake without the O-rings around the ports, the single fin goes into the groove and the double fin side is visible.
I attempted to upload it but I think the file is way to big (40 mb) to upload to this server...
TheBlueKnight - You have an email address or something to try that way and you can put it back up on my-space? I don't know of any other way to do it?
I also tried uploading to photobucket, and thats not doing a damn thing for some reason. So I dont know what else to do besides doing it over a messaging system such as AIM.
