Fast 90/90 Stock MAF question
I did some searching, but couldn't find any good answers. I have what's basically a max effort stock CI LS1 with TFS 215 CNC heads & high comp. The intake is a Fast 90 with a NW 90mm TB, but I'm still running a stock MAF. Would I pick up anything by going to an 85mm MAF, or an aftermarket 90mm TB. From my findings so far if it's already got a good tune with the 78mm MAF, it won't be hard to retune for a larger MAF, I'm just wondering if the 78mm TB & the 78mm lid is a restriction to the Fast 90/90 setup & if I will pick up anything with a larger MAF/Lid setup?
I'll check with my tuner RWTD to see what he says about SD vs bigger Maf, I've just been staying away from SD tunes due to the weather and DA variations where I live. As I said above my buddy popped his motor due to a SD tune & a severe weather change. The tuner will not be mentioned, but he's one of the more respected in the LSx community & my buddy still popped his motor.
